RV.Net Open Roads Forum: For those that think you don't need WD with a dually.
Search only in Tow Vehicles
 > For those that think you don't need WD with a dually.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/06/12 09:19am Link  |  Print  |  Notify Moderator
He didn't need a weight distributing hitch. What he needed to do was pull over and wait for the wind to die down, then continue the trip.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
RCMAN46
NorthWest
Posted: 05/06/12 12:39pm Link  |  Print  |  Notify Moderator
Do not agree. With that large of a trailer there was a significant amount of weight being removed from the truck steering axle. This makes it much more difficult to regain control. also he probably did not have any kind of sway control.
jvernon
ok
Posted: 05/06/12 02:45pm Link  |  Print  |  Notify Moderator
this vid is why i pull a 5ver
mowermech
Billings, MT
Posted: 05/06/12 04:27pm Link  |  Print  |  Notify Moderator
If the wind around Livingston, MT can be so strong that they close the freeway (I-90) to "High Profile Vehicles" including 80,000 lb. semis, your fifth wheel doesn't stand a chance! That (closing the freeway due to wind) happens frequently.
Fifth wheels can, will, and have blown over, too!
However, be that as it may, I agree, having owned, and driven with, TTs and a fifth wheel, I will never go back to a TT.
I also agree, a WDH and sway control would not have been any help in the accident shown, and may have made the situation much worse. Just my opinion, of course
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Turtle n Peeps
California
Posted: 05/06/12 05:28pm Link  |  Print  |  Notify Moderator
That is what this guy said....oops. Well that did not work out so good.
This worked out good. Oops, no it didn't
Once your in a wind storm like that you can do nothing. Driving, sitting, WD, no WD, 5er, TT, sway control, no sway control.Your toast. Nothing you can do will help. NOTHING. Houses have been blown over in storms. Now I guess someone would argue that they had no WD and if they did nothing would happen.
The only thing you can do is hope and pray you're never in one; stand still or driving.
outside the fire"
wolverine68
Alberta, Canada
Posted: 05/06/12 09:55pm Link  |  Print  |  Notify Moderator
If the wind is from a constant direction, park it nose into the wind.
04 Chev LLY Duramax
07 Desert Fox 24AS Toyhauler
Bikes and quads to fill the toyhauler
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/07/12 09:29am Link  |  Print  |  Notify Moderator
Yep, pull over and find a place to park it where the wind is not blowing directly on the large sail area of the side of the trailer. That is why I say, he did not need weight distribution, what he needed was to pull the thing off the road and wait out the storm, instead of keep driving it.
hawkeye-08
Northwest
Posted: 05/07/12 10:53am Link  |  Print  |  Notify Moderator
You must not have watched the video. The wind blew the trailer over, nothing to do with the front end light or the sway control not working. Plain and simple, the wind was too strong from the side...
mkirsch
Rochester, NY
Posted: 05/07/12 12:03pm Link  |  Print  |  Notify Moderator
"what he needed was to pull the thing off the road and wait out the storm, instead of keep driving it."
That's all well and good, but weren't they on a limited-access highway? It wasn't like they could just pull the rig crossways in the road...
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
RandACampin
Kathleen, Georgia
Posted: 05/07/12 12:08pm Link  |  Print  |  Notify Moderator
Dually has nothin to do with a WDH. The need for a WDH is based on reciever capacity has nothin to with 1/2, 3/4 1-Ton or MDT. If the tounge weight exceeds the rating of the recievers non weight distributing rating then you need a WDH. There are no other reasons.
