RV.Net Open Roads Forum: Class A Motorhomes: Dry camping gen set
 > Dry camping gen set
David0725
Posted: 05/03/12 02:02pm Link  |  Print  |  Notify Moderator
If you had read my last post you know this is my first time dry camping! so how long can I run the generator? with out shuting it down its a oldschool diesel generator with no temperature gage. all I can do Is keep water in it And hope i dont lost a fan belt. yes I worrie alot but I did put the gen turi pipe on.
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
skipnchar
Topeka or somewhere else
Posted: 05/03/12 02:06pm Link  |  Print  |  Notify Moderator
It will probably be determined by the campground rules where you're staying.
mr300ce
Mojave Desert, Ca
Posted: 05/03/12 02:15pm Link  |  Print  |  Notify Moderator
x2 otherwise you can run it till you run out of fuel, or something finally wears out and it breaks. (or until it needs an oil change)
Fulltime livin' & lovin' it in '94 Bounder 32h.
Chevy 454ci Retire in 3yrs.
David0725
Posted: 05/03/12 02:17pm Link  |  Print  |  Notify Moderator
skip they said we can run all night if we like. but can the gen set handle running for a long time or do I need to let it rest?
2oldman
Winchester WA
Posted: 05/03/12 02:20pm Link  |  Print  |  Notify Moderator
I can't think of any reason a generator needs to 'rest'.
bluwtr49
Green Valley, AZ
Let it run as look as it's needed.
However, the batteries should handle a lot of the housekeeping loads unless you need AC. Running the gen set without any load is somewhat counter productive.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
Blueflame1
Yes
Posted: 05/03/12 02:24pm Link  |  Print  |  Notify Moderator
Just run it for 3 hours in the middle of the day, you don't need to run it 24 X 7.
Switch it off at night - nothing worse than an inconsiderate camper running a generator all night long.
Pogoil
Oregon Coast
Why would you need it to run all night. Nothing against generators have one of my own but in 20 plus years of camping I have never run mine all night.
Just curious.
Pogoil.
doc brown
Redondo Beach, CA,
If maintained as recommended it will run 24/7 as long as there is fuel. When I dry camp there are times when I run the gen for 5 days straight.
Steve,Kathy,Josh & Morpheus the Basenji
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2008 Wrangler X Rubicon/Blue OX Tow Bar/Ready Brake
zman-az
Northern AZ
Posted: 05/03/12 02:28pm Link  |  Print  |  Notify Moderator
Just curious.
Pogoil.
If you are down south you would need it 24/7 for AC in some locations.
