FordDiesel250
I.P. Texas
Does anyone have any tried and true method for keeping mice out of your fiver when parked and stored?
45Ricochet
North Idaho
I used the insulating foam (great stuff) to get every little crack filled and seemed to work pretty good so far.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
the bear II
Torrance CA.
A friend in a mice infested area claims moth balls work great. He keeps the balls in containers with lids. When stores the trailer he puts a container inside the trailer and takes the lid off. He places the other containers in the storage compartments with the lids removed. When he gets ready to take the trailer out he closes up the containers puts them in his garage and then airs the trailer out for a half a day windows and vents open.
Since he's been doing this he hasn't seen any evidence of mice in his trailer.
wandering1
Put the cheese out away from your RV.
HR
Duke-44
Wyoming Rockies
The moth balls do work. I put them around the tires and at the base of the front and back jacks and have had no problem since.
I would be very hesitant to put them inside the unit. My experience is that the smell will repel you, too. It will take weeks not days for the smell to disipate.
cabanaman
florida
Just had our first mouse ever,put a trap in the pot and pan cabinet where we could hear the rustling.Trap went off an hour later.Problem solved.
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
http://www.gofundme.com/Carebear (my daughter)
subdoc44
Arlington, WA
Steel wool around all cracks works.
2007 3500 Silverodo 4x4 ext cab
2013 Redwood 36 RL
2-Corgies (Molly and Priscilla)
kingrick5
Canada
I've heard mint oil works.
Mile High
Denver, CO
subdoc44 wrote: Steel wool around all cracks works. X2 especially through the pipe penetrations. I sealed up my old rig pretty tight after having a mouse. When we got our 2007 home I looked underneath and said ...forget it...! The floor already looked like swiss cheese. It would have taken 100 lbs of steel wool. We just went to sonic devices and luck.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
jeepbluetj
California
In before the dryer sheets...
Seriously: Traps and close up the openings they get in from.
