RV.Net Open Roads Forum: Class A Motorhomes: red max replacement
 > red max replacement
dturm
Munster, IN
Posted: 05/04/12 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
larry cad wrote:
Lowes is changing over to the Zep product. Same stuff, more money. Works the same as Red Max
I was in our Lowes yesterday and they had all the ZEP products in, no more RMP on the shelves.
crankshop1000
se michigan
Posted: 05/04/12 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
wildtoad wrote:
I used Mop-N-Glo on my 2000 Hurricane at it looks great 1 year later. Available everywhere.
Me too.I agree.Maybe Mop N Glo is considered redneck because you can get it at WalMart.
rchonly
Kingman, Arizona, USA
Posted: 05/04/12 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
ZEP is the manufacturer of RED MAX as RED MAX is a private label for Lowes. It's the same product.
Look up the ZEP name you'll find the history.
Roger
1991 - 38" American Eagle - 8.3 Cummin's w/Allison 4spd
(Purchased 4-15-10 w/5,600 miles on it)
99 Dodge Durango/SLT 4X4 - Toad
michahicks
Waterford/Gaylord, Mi
Posted: 05/04/12 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Go here and punch in your zip code to see if you can find a store that's carrying it in your area.
http://www.lowes.com/pd_216595-531-RMPLM128_?PL=1&productId=3024836
Regarding what Red Max Pro, you're after #3
1997 38' HR Endeavor, 275 Cat, Freightliner
2003 CR-V Toad, Blue Ox, Ready Brake
brick
Kiawah Island, SC 29455 USA
Posted: 05/09/12 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have been using Red Max for about a year with good results but now the front end is loosing the shine and is starting to turn grey in some areas. The sides look fine. It will not last for ever and it is better to recover sooner then after it start to loose the shine. Little hard to get off before recoating. I did find it at Lowes on the top shelf not very visable.
1997 Kountry Aire,Ford
Banks
Saturn L series
wny_pat
Western NYS
Posted: 05/09/12 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
belairbrian wrote:
So which Red Max is it? Our local lowes has "Stain resistant" and "low maintenance."
Is either of these the correct one?
"Red Max Pro low maintenance Step 3" or "Zep Wet Look Floor Finish Step 3".
vegasken34
Las Vegas Nv. USA
Posted: 05/11/12 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the input. I bought the Zep & am in the process of putting it on. Will update if I ever get it done. It's close to 100
degrees outside.
vegasken34
Las Vegas Nv. USA
Posted: 05/15/12 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Someone wrote "don't get upset if it looks bad after a couple of coats". I was very upset when after 3 coats it still looked horrible but today yes it is beginning to shine. What a difference a few coats make. so if you are just starting have patience, it will "shine" when it's time!!!!!!!!!
wilburno
central louisiana
Posted: 05/20/12 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Home Depot carries the ZEP products. It worked great on mine.
