RV.Net Open Roads Forum: Tow Vehicles: Real World Weights
Search only in Tow Vehicles
 > Real World Weights
1Wheeldrive
The Rockies
Posted: 05/03/12 05:16pm Link  |  Print  |  Notify Moderator
I am looking at upgrading my truck, 2003 Silvarado HD 2500, GVWR is 9200 lbs. I would like to know if anyone out there has actually weighed their 2010+ Silvarado 3500 crewcab long box DRW, and 2012+ Silvarado crewcab long box SRW. I know what the GVWR and "payload" figures the manufacturer publishes, but without an actual weight, those numbers don't mean much.
Thanks in advance for any one who has weighed their truck.
APT
SE Michigan
Posted: 05/03/12 06:08pm Link  |  Print  |  Notify Moderator
You can get a good survey at a dealer lot opening driver's doors. Look for the Tire and loading sticker for as equipped payloads. FWIW, my buddy bought a 2012 Silverado LT 3500DRW and and his payload is just under 5000 pounds. It also rides unloaded and loaded better than his 2003 3/4 ton.
2012 VW Passat TDI
agesilaus
North Florida
Posted: 05/03/12 06:13pm Link  |  Print  |  Notify Moderator
The weights shown on the door sticker are for a bare truck, 150 pound driver, and a empty fuel tank. Not even close to real world after you start adding accessories, real driver and passengers and a full fuel tank.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
skipnchar
Topeka or somewhere else
Posted: 05/03/12 07:48pm Link  |  Print  |  Notify Moderator
Brochure payload numbers are useless but the numbers posted in your door post should be right on accurate. THOSE numbers take into account all factory installed options.
ib516
Up here!
Posted: 05/03/12 08:13pm Link  |  Print  |  Notify Moderator
No, the weights on the "TIRE AND LOADING INFORMATION" sticker are for THAT truck.
IN THIS COMPARISON TEST, each truck was weighed on a CAT scale, and the 2012 GMC 3500 DRW long bed 4x4 weighed 8140#.
* This post was edited 05/03/12 08:27pm by ib516 *
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
LJPeterson
South Eastern Washington
Posted: 05/03/12 10:24pm Link  |  Print  |  Notify Moderator
I just put my 2012 GMC Denali 3500HD (crew cab long box with dual rear wheels and 4X4) on the scale here and with full tank and two people in it with the gooseneck hitch installed in the bed it weighs 8750 lbs. That was a certified scale also.
APT
SE Michigan
Posted: 05/04/12 07:23am Link  |  Print  |  Notify Moderator
The yellow Tire and Loading sticker are for the every passenger vehicle as equipped from the factory. This varies based on trim level, options, cab/bed sizes, and includes all fluids filled (oil, fuel, etc). No people.
Tow ratings are often listed with a 150 pound driver.
agesilaus
North Florida
Posted: 05/04/12 07:48am Link  |  Print  |  Notify Moderator
OK, I stand corrected. Heh
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/06/12 09:24am Link  |  Print  |  Notify Moderator
You're looking at about 400 lbs or so difference in scale weight between otherwise equally equipped SRW and DRW one-ton pickups. Most of that weight difference is on the rear axle, due to the 2 extra wheels and tires.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
1Wheeldrive
The Rockies
Posted: 05/06/12 05:23pm Link  |  Print  |  Notify Moderator
Thanks LJPeterson, that is exactly the information I am looking for, and SoCalDesertRider,thanks also.I was estimating about 500 lbs difference, which is probably a little high.
Glenn
