RV.Net Open Roads Forum: Beginning RVing: Detector alarm?
 > Detector alarm?
Musky50
Ky
Posted: 05/03/12 07:08pm Link  |  Print  |  Notify Moderator
I think its a gas detector, Jayco TT on the side of the dinnett. TT has not been plugged in for 2 weeks when I came home this evening I heard an alarm coming from TT. It was 92 degrees and trailer was closed up. I opened the vents and it didnt stop until I plugged it up,it stopped immeadiatelty. Do these have a small AA battery backup or anything?
skipnchar
Topeka or somewhere else
Posted: 05/03/12 07:34pm Link  |  Print  |  Notify Moderator
Usually they do not and run solely from the house battery. When the battery gets low they will chirp.
Jim Shoe
Amelia, OH
Posted: 05/03/12 08:16pm Link  |  Print  |  Notify Moderator
IMO any gas detector that produces as many false alarms as the typical RV gas detector does, is useless. The last time mine went off when I began using the sweeper (not gas powered) and with the gas turned off at the outside tank, I unplugged it. Before my next trip, I'll purchase a portable leak detector. I'll check around the stove/oven before going to bed. I stay at FHU parks when traveling, so I don't run the reefer on gas anyway. And I don't overnight in weather that requires anything more than an electric space heater.
Retired and visiting as much of this beautiful country as I can.
UsualSuspect
Saugus, CA
Posted: 05/03/12 08:28pm Link  |  Print  |  Notify Moderator
Could be the battery going dead, and the propane detectors usually need to be replaced every 5-6 years.
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC
2011 Toyota Tundra
Gone but not forgotten, 2008 Jayco 299 RLS
bikendan
Napa, Cal.
Posted: 05/04/12 01:22am Link  |  Print  |  Notify Moderator
pretty common when you don't have the trailer plugged in or don't have a battery disconnect switch.
there are many parasitic power drains on RVs and without shore power or the battery disconnected, these will drain the battery in a few days, thus setting off the alarm which is hardwired to the battery.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
NanciL
Bakersville, NC, USA
Posted: 05/04/12 03:58am Link  |  Print  |  Notify Moderator
It is telling you that your trailer battery is going low.
I like the fact that it is a low battery warning
Jack L
Jack & Nanci
 > Detector alarm?
