Mickey456
Ohio
What is the extra cost to drive a Class A, with air conditioning ON, versus OFF. Does anyone know what that would roughly cost....we have a 32 foot gasoline coach. Thank you so much.
rk911
Wheaton IL
i 'spose you could figure a way to calculate it but i think it would be negiglible. if your budget is *that* tight then you'll need to find other ways to economize. we drive with the dash air on and the genny running so we can run the coach air. i'd rather arrive cool and comfortable instead of hot, sweaty and a few pennies richer.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
jauguston
Bellingham, WA
If you have to worry about the cost of using your AC it may be the RV lifestyle is not for you.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
zigzagrv
Nazareth, PA
Depending on how hot it is, a rough guess would be 1/2 to 1 gallon per hour.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
'95 Tracker toad
harold1946
Surprise Arizona
If you are referring to the dash air it will be very little, probably not measurable.
If the genny and roof ac it would average .5-.8 gallons per hour. depending upon whether it was running under full load.
Most dash ac's will not cool the whole coach. We run the genny and use the roof ac whenever the dash will not handle it.
I apologize for the rude comments made.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
pianotuna
Regina, SK, Canada
Hi,
It takes about 35 horsepower to run the "dash air". It is not a significant extra load. The only true way to tell would be to do a 3 or 4 thousand mile trip with air on, and then do exactly the same trip with the air off.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
fcooper
Richmond Hill, Georgia
You can research the fuel use of your generator based on load, and calculate the direct cost. I figure my onan quiet diesel 7.5 uses 1/2 to slightly more gallons per hour under load, so my direct cost is about $2.00 to $2.50 per hour. Of course there are other costs, such as oil, filter, fuel filter changes for the genset. Mine gets changed based on age, so that is a cost I'm going to pay anyway.
Overall, the cost of running the generator and air conditions is not a material cost considering what it costs to move the motorhome down the highway.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
What Next
Northern IL
Roughly 1/2 gallon an hour so little less than $2 an hour.
Now if dash air is off you may get slighly better mpg so you almost come out even. At least that is what I tell myself.
2008 Southwind 32v
rk911
Wheaton IL
pianotuna wrote: Hi,
but then you'd not be able to precisely duplicate the weather conditions, quality of the fuel, the speed at which you drove and so on. it's an interesting intellectual exercise but that's about all.
pianotuna
Regina, SK, Canada
Hi rk911,
That's why 3 or 4 thousand miles. That would tend to average out the differences in temp wind and etc.
I suspect the differences are pretty minor.
