RV.Net Open Roads Forum: Fifth-Wheels: Is it compatible?
 > Is it compatible?
goobers
n/a
Posted: 05/03/12 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
A friend of mine has a 2008 Dodge Ram 6.7 Cummins and trying to find a hitch for his Rv. He has a new hitch site from Reese and just curious if somebody here already purchased this kind of hitch? Looking for further information before deciding on getting one or if not, can any one give another site we can check out?
http://www.hitchanything.com/Reese-30K-Low-Profile-Fifth-Wheel-Hitch-30054.html
I also used that site in getting mine but its a different kind of hitch.
enblethen
Moses Lake, WA
Posted: 05/03/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
The hitches would be the same for most rigs. What is different is the frame rails which must be purchased separately and are rig specific.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
pulsar
Lewisville, NC
Posted: 05/04/12 04:29am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
chuggs
Posted: 05/04/12 04:46am Link  |  Quote  |  Print  |  Notify Moderator
30K... I'd expect to mount a hitch like that on the back of a freightliner... Does he have a chassis cab??
For regular bed truck...
As far as mounting...
There are 4 basic types that I know of....
1) Industry Standard Rails. Like the REESE 30035. They stay in the truck bed with or without a hitch on them.
2) Proprietary Rails/ Underbed Mounts. Like the REESE Elite Series, the Valley/Huskey UBS, or the Pull Rite SuperRails. These can be removed from the truck when not in use...leaving a "clean bed". Specific hitches go with specific rails.
3) Gooseneck conversion... Like the B&W companion. Can also be removed from truck bed. Pull Rite makes a rail adapter to allow their hitches to fit the B&W turnover ball mount as well.
4) The new "OEM" style hitch. I think it's a FORD thing...but other manufacturers might be doing it. The truck comes from the manufacturer with the mounting brackets already installed. I believe the mount is compatible with REESE Elite hitch systems. Other manufacturers are coming out with hitches ready to mount into these brackets as well. Pull Rite has one for the OEM hitch mount.
Most of the super heavy duty hitches... 24K plus...will have a different mounting system due to the weight.
Anyway... I would probably pick a hitch that's more compatible with the limitations of the truck. Unless he's getting a 4500/5500... I'm not sure he needs a 30K hitch.
When you say he's got a "new hitch site by reese"...what do you mean exactly? The truck came with the OEM mount? A previous owner installed some type of REESE rails? What does this look like??? Do you have two parallel bars across the bed with holes? Or just 4 holes in the bed...with mounting brackets underneath?? A specific website??
We can probably help out more if we knew...
Year Model? 2008
Model Truck?
Cab style?
Engine? 6.7L HO Cummins
Transmission?
Axle Ratio?
Short Box/ Long Box?
Anticipated Gross Tralier Weight?
* This post was edited 05/04/12 05:01am by chuggs *
Bill1374
northern New York
Posted: 05/04/12 05:41am Link  |  Quote  |  Print  |  Notify Moderator
Per the Reese web site (Reeseprod.com) that is a low profile hitch designed for medium duty/heavy duty trucks, likely in conjunction with a hauler bed on the truck. I don't believe that it would have enough vertical adjustment to provide clearance for a pickup bed. It also does not mount to standard rails.
If his truck is a 4500/5500 cab and chassis with a hauler bed, then yes thats a good hitch.
Bill
2011 Hitchhiker Discover America 345RSE
2006 Dodge quadcab,dually 2 wheel drive
45Ricochet
North Idaho
Posted: 05/04/12 11:25am Link  |  Quote  |  Print  |  Notify Moderator
I don't think it will work on a normal pickup bed.
Build for serious trailering; especially designed for use on medium duty conversion trucks.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
cabanaman
florida
Posted: 05/04/12 11:42am Link  |  Quote  |  Print  |  Notify Moderator
I agree that 30K is overkill,I am running a reese 15K.It has been on 3 trucks over about 8 years now.
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
http://www.gofundme.com/Carebear (my daughter)
RedG
Fort Worth Texas
Posted: 05/04/12 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like overkill to me. And probably not compatible.
I think if it was me, I'd save $600 and go with the Reese 16k Pro Hitch or it the 5'ver is really heavy, go with the Pro 20k.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
goobers
n/a
Posted: 06/25/12 04:42am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys, I think so too 30k is overkill so he decided to go for 16k instead.
http://www.hitchanything.com/Reese-Hitches/?catid=373
 > Is it compatible?
