craigspeer2001
south carolina
I have a 33 ft winebago brave I am curiuous to why both acs will run off generator is this ok or do I have something wrong with my selector switch.
rk911
Wheaton IL
39-amp coach or 50-amp coach? power management system or not?
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
hottubkid
SCHAUMBURG,IL
Should work
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
What Next
Northern IL
5500 states in book it will handle 2 regular air conditioners fine. Mine does and with power management system it runs everything fine.
2008 Southwind 32v
stew&Jan
Lanesville, IN
I've been running both on our 5500 Onan for years and have never had any problem
edatlanta
Panama City Beach, FL
My 5500 runs both a/c's fine. One is a 15K and the other is a 13.5K. No problems at all.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
jerseyjim
New Jersey
My 5500 Generac runs both of mine, no problems. Your Onan should, too.
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
My Onan 5500 runs both all the time with lots of power to spare.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
SolidAxleDurango
OK, USA
A 5500 will run both A/C's - it's designed to....
However, if you have trouble, check your 110v breaker box. On one RV I had, both A/C's were on the same leg of the panel... Can't run both A/C's like that.
I moved the bedroom A/C to the other leg and all was happy then.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
PeppyPilot
NW Chicago Suburbs
Ours works just fine for both compressors (we have basement air), equivalent to running two A/Cs. We can also run microwave, electric hot water, electric cooking appliance etc. at the same time.
The math: a 5500 watt generator yields about 46 amps (5500/120 volts). Your two A/C's should pull ~22 to 25 amps when both operating, only about half a load.
We can monitor our amps drawn and we sometimes pull 40+ with multiple draws simultaneously. EMS will shed a load if it gets too much.
CJ and Pepe
2003 Itasca Suncruiser 33V
Workhorse W-20 chassis
2004 Jeep Liberty Limited w/Blue Ox
