RV.Net Open Roads Forum: 5500 watt onan questions is it ok to run both ac
 > 5500 watt onan questions is it ok to run both ac
craigspeer2001
south carolina
Posted: 05/03/12 07:33pm Link  |  Print  |  Notify Moderator
I have a 33 ft winebago brave I am curiuous to why both acs will run off generator is this ok or do I have something wrong with my selector switch.
rk911
Wheaton IL
Posted: 05/03/12 07:34pm Link  |  Print  |  Notify Moderator
39-amp coach or 50-amp coach? power management system or not?
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
hottubkid
SCHAUMBURG,IL
Posted: 05/03/12 07:37pm Link  |  Print  |  Notify Moderator
Should work
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
What Next
Northern IL
Posted: 05/03/12 07:40pm Link  |  Print  |  Notify Moderator
5500 states in book it will handle 2 regular air conditioners fine. Mine does and with power management system it runs everything fine.
2008 Southwind 32v
stew&Jan
Lanesville, IN
Posted: 05/03/12 07:43pm Link  |  Print  |  Notify Moderator
I've been running both on our 5500 Onan for years and have never had any problem
edatlanta
Panama City Beach, FL
Posted: 05/04/12 03:52am Link  |  Print  |  Notify Moderator
My 5500 runs both a/c's fine. One is a 15K and the other is a 13.5K. No problems at all.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
jerseyjim
New Jersey
Posted: 05/04/12 04:24am Link  |  Print  |  Notify Moderator
My 5500 Generac runs both of mine, no problems. Your Onan should, too.
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 05/04/12 05:08am Link  |  Print  |  Notify Moderator
My Onan 5500 runs both all the time with lots of power to spare.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
SolidAxleDurango
OK, USA
Posted: 05/04/12 05:11am Link  |  Print  |  Notify Moderator
A 5500 will run both A/C's - it's designed to....
However, if you have trouble, check your 110v breaker box. On one RV I had, both A/C's were on the same leg of the panel... Can't run both A/C's like that.
I moved the bedroom A/C to the other leg and all was happy then.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
PeppyPilot
NW Chicago Suburbs
Posted: 05/04/12 05:30am Link  |  Print  |  Notify Moderator
Ours works just fine for both compressors (we have basement air), equivalent to running two A/Cs. We can also run microwave, electric hot water, electric cooking appliance etc. at the same time.
The math: a 5500 watt generator yields about 46 amps (5500/120 volts). Your two A/C's should pull ~22 to 25 amps when both operating, only about half a load.
We can monitor our amps drawn and we sometimes pull 40+ with multiple draws simultaneously. EMS will shed a load if it gets too much.
CJ and Pepe
2003 Itasca Suncruiser 33V
Workhorse W-20 chassis
2004 Jeep Liberty Limited w/Blue Ox
