RV.Net Open Roads Forum: General RVing Issues: Repost to my bad smell
 > Repost to my bad smell
Louie & Eva
New Haven Ct
Posted: 05/03/12 07:35pm Link  |  Print  |  Notify Moderator
WE have found the problem with the bad odor coming from our storage areas. It is coming from the batteries, The tops had come off and most of the water is gone. We are pretty sure that's our problem. I want to thank everyone for your help.
Montana 2008 Mountaineer travel trailer 32FLD
2006 Ford F350 PSD, Lariat, CC, LB, SRW and Blue ox sway control
pianotuna
Regina, SK, Canada
Posted: 05/03/12 07:41pm Link  |  Print  |  Notify Moderator
Hi,
Now you get to decide what to do about replacement!
The whole battery discussion swings on what the goals are.
If you want the minimum number of cells then six individual two volt cells is the best of all worlds (600 amp-hours per cell, and up).
If there is room for an odd number of batteries and the choice is between six volt and twelve volt jars, twelve volt wins on capacity.
If there is room for only two batteries twelve volt wins on redundancy and six volt wins on the number of cells.
If a large inverter (1500 watts and up) is to be run at "full bore" then twelve volt wins even against six six volt (assuming equal amp-hours of capacity), due to the larger voltage drop exhibited by the thicker plates.
Flooded cells remain, for the time being, the "best bang for the buck", but the trade off is regular maintenance and a pair of wool pants.
If one does go to agm chemistry, it would be wise to heed the advice of the particular maker on charging parameters, given that the cost of such batteries may far exceed the cost of a good converter.
Most RV's are woefully low on amp-hours of capacity, and many folks abuse their battery bank by going to far lower states of charge than is good for longevity. To me, it is a no brainer to maximize the capacity.
Balanced wiring for battery banks is often hit and miss (mostly miss, I fear). It should be addressed.
No matter what voltage or chemistry is used, good charging practice need to be followed. If that is done, 2 volt, 12 volt, and 6 volt battery banks may last many years.
So, find out the goals, use what ever works for a battery bank, and go camping.
For my further thoughts on battery banks surf here:
Battery Selection
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
fla-gypsy
North Florida
Posted: 05/03/12 08:45pm Link  |  Print  |  Notify Moderator
Glad you found it and you probably have the cleanest storage compartments ever seen (LOL). BTW, your batteries are most likely toasted. Now you get to see how expensive being an RV owner can be.
ScottG
Bothell Wa.
Your going to want to upgrade your converter. Your existing unit slowly overcharges the batterys resulting in the damage you found.
Thanks for updating us!
Scott, Grace and Wesly
H0NDA eu2000i
SWD
Land of Living Skies
Posted: 05/03/12 09:29pm Link  |  Print  |  Notify Moderator
Thanks for the update...figured it had to be the batteries but what threw me was that you said it wasnt a sulphur smell. My vote is for 2 6volt batteries.
FunnyCamper
Southeastern
Posted: 05/04/12 05:43am Link  |  Print  |  Notify Moderator
whew that has to be a relief. bad smells hanging aruond are not cool
hope it all clears up for you now
Louie & Eva
New Haven Ct
Posted: 05/04/12 07:12am Link  |  Print  |  Notify Moderator
THANK YOU EVERYONE!!!!!!
mr. ed
Madison, SD (but usually elsewhere)
Posted: 05/04/12 05:55pm Link  |  Print  |  Notify Moderator
I don't understand how the "tops" could have come off by themselves? To get my battery filler tops off I have to pry with a screwdriver...
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
pianotuna
Regina, SK, Canada
Posted: 05/04/12 07:21pm Link  |  Print  |  Notify Moderator
Hi mr. ed,
If one cell shorts out the rest will gas violently. The pressure can literally pop the tops off the battery.
mr. ed
Posted: 05/05/12 07:17am Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi mr. ed,
Thanks for the explanation, Pianotuna....
