RV.Net Open Roads Forum: General RVing Issues: Galvanic corrosion?
 > Galvanic corrosion?
rerod
Iowa
Posted: 05/03/12 07:41pm Link  |  Print  |  Notify Moderator
I have a aluminum trailer and was a bit surprised to see the axle carrier was steel.
Is Galvanic corrosion a concern in a trailer environment? I ask because I need to add supports to my aluminum frame to secure two motorcycles and wondered if using anything other than welded aluminum was a bad idea?
Or is Galvanic corrosion only a concern in wet salty area's?
Thanks
1995 E350 6bt/nv4500, 2006 Featherlite 24' surv toyhauler, 2007 DRZ400s well farkled, 1985 Vmax stock, 1985 Vmax custom
skipnchar
Topeka or somewhere else
Posted: 05/03/12 08:01pm Link  |  Print  |  Notify Moderator
Not a concern unless you immerse it in water
christopherglenn
a little over an hour from Yosemite
Posted: 05/03/12 10:38pm Link  |  Print  |  Notify Moderator
Paint the joint. Corrosion needs oxygen, a good layer of paint (We spec epoxy paint alot) with decent prep (clean the area of anything loose) and go for it. All you are trying to hit is the joint + maybe 1/4 inch of each piece.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
EgorKC
Kansas
Posted: 05/03/12 08:21pm Link  |  Print  |  Notify Moderator
The Manufacturer should have isolated the two metals with a dielectric break (plastic or rubber washer) to prevent the issue as a standard practice. There will be a problem if they did not but it will accrue over time. Normal humidity plus water splash from roads during rain is enough to start the corrosion process. Having said that, it will be a slow process and you can ask your dealer to check those connections each time you have the bearings or breaks serviced.
I work for a supplier to the Metal building industry and galvanic reaction is a regularly discussed and addressed topic. You are wise to question but I suspect the Manufacturer already addressed it. Simple annual inspections of the joints should point out any potential issues before they become problems.
Greg
You cannot stop growing old but you don't have to grow up.
Chef/Pilot
DW/Navigator
2 Sons, 1 DIL, 1DIL planned, 1 Grandson, 1 Granddaughter.
2012 F350 XLT 6.7 Powerstroke 4X4 SWD Crewcab.
2012 Wildcat 313RE-OK
rerod
Iowa
Posted: 05/04/12 06:44am Link  |  Print  |  Notify Moderator
Thanks! The axle carrier or connection points to the aluminum trailer frame show no signs of Galvanic corrosion that I can see, yet. Makes me wonder what they were thinking or what method they used to slow the process. Even with rubber washers or paint, you still have a bolt connecting the two materials.
My project involves mounting two Standsbetween the I beams because first, I dont want to drill through the top only the centers. And second, only half of the mounting bolts would be to aluminum if I did that.
I need to add 4 cross pieces to mount the stands to as I dont trust the plywood to hold 1200 lbs of motorcycle.
So the best method would be to fabricate cross pieces from steel and bolt them in to the center of the I beam web with stainless bolts and maybe rubber or paint separating the steel from the aluminum? Or would welding 6061 pieces in be a better method?
From the fact featherlite drilled a 1" conduit hole in the center of these I beams.. Drilling more 3/8" holes might be the best bet maybe.
Thanks
Galvanizd
Looking at the Mogollon Rim ...... For a bit.
Posted: 05/04/12 08:53am Link  |  Print  |  Notify Moderator
hmmm
Francesca Knowles
Port Hadlock, Washington
Posted: 05/04/12 11:55am Link  |  Print  |  Notify Moderator
Galvanizd wrote:
hmmm
Well?
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
rerod
Iowa
Posted: 05/09/12 06:45pm Link  |  Print  |  Notify Moderator
I just isolated the steel from the aluminum with multiple layers of electrical tape.
Happy Prospector
The Great Sonora Desert
Posted: 05/10/12 03:57am Link  |  Print  |  Notify Moderator
My Aluminum horse trailer had heavy duty black 3M tape between the axles and the aluminum frame.
Kevin
Kevin
Retired, Fulltime RV'er
1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler
2007 Yamaha Grizzly 700 (Green-It's your Daddy)
One Tough Kitty Named Bob
rerod
Iowa
Posted: 05/10/12 07:02am Link  |  Print  |  Notify Moderator
Kevin
Same here.. Except my axles join to a steel sub-frame first.
I hope that prevents any corrosion.
