RV.Net Open Roads Forum: Travel Trailers: Leveling the TT
 > Leveling the TT
JAL_Camper
Raleigh, NC
Posted: 05/04/12 07:37am Link  |  Print  |  Notify Moderator
I back to where I want to set up, look at large level on front of TT to see if side to side adjustment is needed. If so, I pull forward or back 5 ft. or so, put down leveling blocks (I use beveled 2 x 10's that I can bolt together, if needed, and also have treated plywood if lesser correction is needed. Back up onto leveling boards and check level again. If good, disconnect TT hitch and move TV forward, I then level front to back via. tongue jack -- I have a small level attached to tongue. Then stabilizers are deployed to firm it all up.
JAL
2002 Burb 2500 LT, 8.1L, Autoride, 4x4
2005 Jayco Eagle 298BHS
Check It OutReese HP 1,200 Lb. Bars WD/Dual Cam HP Sway Control/Prodigy® Brake Control
Family: Two Baby Boomers with Two Generation Y Kids -- All RV Generation
CAMPED IN:
korbe
Northern California
Posted: 05/04/12 08:30am Link  |  Print  |  Notify Moderator
I use a 12-inch torpedo level on the kitchen counter. I lift one end of the level to see how high it goes to get it level, and that tells me how high I need to raise witch side of the rig. No need to check it later.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
Bit Bucket
Brookings, Oregon
Posted: 05/04/12 08:31am Link  |  Print  |  Notify Moderator
SolidAxleDurango wrote:
BooRae wrote:
Friends of mine drink a beer to the label on the bottle and set it on the counter.
I drink mine down to the bottom.
X10!!! Darn right!
What's with the partially drank beer??????????
NEVER put down a beer until it's gone!
tspecs
home
Posted: 05/04/12 08:46am Link  |  Print  |  Notify Moderator
X10!!! Darn right!
That's a good way to level the trailer. Drink the can empty, and then lay it down on the dinette table, and observe the rolling direction. For best results, you could lay 6 on the table pointing in all directions. They have to be empty, because any beer sloshing around in them will throw the precision off.
tspecs
feltham
Rochester, NY
Posted: 05/04/12 11:35am Link  |  Print  |  Notify Moderator
X10!!! Darn right!
The six beer approach is exactly what I do. Funny though...I've never had to make any adjustments after the sixth beer. Seems perfectly level every time I use this method.
Me, DW & Sons 13, 11, & 7
2004 Yukon Denali XL
2011 Jayco Jay Feather Select 29L (April 2011)
2007 Jayco Jay Feather 26L ('07-'11)
CraigBrew
Warren, MI.
Posted: 05/04/12 11:39am Link  |  Print  |  Notify Moderator
I'm new at this also and have a question. When leveling a trailer with a slide out. Do you level before or after you put the slide out?
I know that you can level it with it in and put the jacks down but that is not the way the Trailer will sit. All that weight sliding out is going to move something. Last trip I made it so that the side with the slide out was a bit high then slid out the slide and it was just right.
MitchF150
Washington, the State
Posted: 05/04/12 11:56am Link  |  Print  |  Notify Moderator
fordsooperdooty wrote:
I now use the Google Satellite Earth Link GPS RV Refrigerator Leveler System...it's a bit spendy at $6,000.00, but accurite within .0000010 inch.
On reflection, I suppose my single bubble level that cost 2 bucks at Camping World was just as accurite when I set it inside the refrigerator.
That's funny!
I use the $2 round bubble and place it on the front hitch and it will tell me side to side and front to back in one placement.
Adjust accordingly.. If side to side is off by a full bubble, I know I need one level of boards on the low side. Other wise, I just lower the jacks and call it good... After, un-hitching and setting front to back of course...
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
CavemanCharlie
Storden,MN
Posted: 05/04/12 05:24pm Link  |  Print  |  Notify Moderator
feltham wrote:
X10!!! Darn right!
dtzackus
Cumbola, PA
Posted: 05/04/12 05:52pm Link  |  Print  |  Notify Moderator
I actually called Gulfstream, they recommended to use a level on the kitchen counter.
Dan, Tammy, Cory, Leah and Adam
2011 Chevy Silverado 2500HD 6.0
2012 Conquest 297DBS
Equal-i-zer Hitch
GM Integrated Trailer Brake Controller
Downwindtracker2
BC
Posted: 05/04/12 09:28pm Link  |  Print  |  Notify Moderator
How much lift will power stab,such as they put Creek Side 20FQ, do?
Our first PUP had to be dead nuts on, for the top to line up when dropping it.I used 9" magnetic torpedo levels on the frame.
Adventure before dementia
 > Leveling the TT
