nadsab
Michigan
...Just wondering......
2003 Four Winds Five Thousand, 21RB, 23.5', Chevy Express 3500 chassis
NorthernLimits
Michigan
Do you out them on your car?
Bordercollie
Garden Grove, CA, USA
I didn't use them and Michelins had serious cracks in sidewalls after 4 years in Socal sun.
pnichols
Santa Cruz Mountains
You can probably apply 303 to your tires once a month and protect them just as well as covers, since it's the UV rays that actually do the damage.
I don't like to mess with covers ... I've actually moved the rig a couple of times forgetting to take them off!
Phil, 2005 E450 Itasca 324V Spirit
crawford
Dandridge Tenn.
Yes,Yes,Yes keep the UV rays off tires is the best way.
phillyg
Front Royal, VA
I've never owned an RV long enough to watch the tires age from birth to death. I used covers on a Class A but they were a PITA and I didn't put them on while out camping, only at home. I'm not totally convinced, but some believe lack of use causes premature aging of tires, too.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
1995brave
San Antonio, TX
Never used covers. Our RV sits in the Texas sun, tires are 10+ years old and the outside of then are just now cracking. Also only washed the tires with soap and water, no type of protectent put on them.
past-MIdirector
Michigan
Been using cover for years and also put 303 on the tires before and after. Tires look great and in over 35 years have not had a blow out from deterioration of a tire. My father-in-law got me started covering tires 25 years ago when the rig sat for more than 30 days.
j-d
Sunny Florida USA
I think covering helps, and I cover between trips and on long campground stays.
I also think that frequent USE of the tires also helps, probably more than any other factor except adequate air pressure. We made a pact: Use the coach at least monthly. This is good for US, let alone tires, brakes and so on. Driving on the tires, warming them up and flexing them, keeps their oils worked throughout the tire.
Previous coach had sat for extended periods and blew a tire shortly after we bought it. The PepBoys "Futura Scrambler" (entry level) tires we put on it looked good after eight years in FL. We didn't cover those, but we used the coach every couple weeks or so.
Covering the FRONTS also keeps rainwater splash off the front disk brakes.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
Bigburd
Tennessee
Didn't cover mine on the TT and they cracked along with the spare that was never used and completely covered. Makes a difference, who knows. I am willing to spend a little on covers to hopefully prevent cracking and associated major cost.
2012 Ford F-450 CCDRW 6.7L
2013 Heartland Cyclone 300C
