RV.Net Open Roads Forum: Travel Trailers: weight distribution help
 > weight distribution help
Cougar2005
St. Stephen, SC
Posted: 05/04/12 07:35am Link  |  Print  |  Notify Moderator
buddy just purchased a tt with 600 lbs of hitch weight and is curious if a wdh with a higher rating say 1000 lbs would hurt anything or does he need to buy one with the 600 lbs rating?
2011 chevrolet 3500 dually cclb D/A
2005 Keystone Cougar 314
downtheroad
Pacific Northwest
Posted: 05/04/12 07:39am Link  |  Print  |  Notify Moderator
If the 600 lbs you are quoting is the "dry" hitch weight then you friend will need a WDH with a bar rating of at least 1000 lbs.
Post the GVWR (gross vehicle weight rating) of the trailer and you will get solid advice here on the Forum.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
VintageRacer
Dundas, Ontario
Posted: 05/04/12 08:00am Link  |  Print  |  Notify Moderator
The bar rating is related to the tongue weight of the fully loaded trailer. I have always preferred to have the next size up of bar, so for 600 true lbs of tongue weight, I would go for the 800 to 1000 lb bars. I bought a new hitch for my new trailer, that has a tongue weight between 400 and maybe 700 lbs, and I find the 600 - 800 lb bars I bought are a little light. It depends on your tow vehicle and hitch as well. 600 lbs on a 2500 series pickup - you can't tell if the bars are on or off. Same deal on a light 1500 series and you need the heavier bars. What the bars do is cut down on porpoising, btw, in terms of ride quality.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
ScottG
Bothell Wa.
Posted: 05/04/12 08:52am Link  |  Print  |  Notify Moderator
I too would go with 1000 Lb bars. Your final hitch weight will be much more than 600.
Scott, Grace and Wesly
H0NDA eu2000i
usmc616
Orange County, New York
Posted: 05/04/12 09:52am Link  |  Print  |  Notify Moderator
I say the 1000lbs bars are fine. Once you load the TT for camping I am sure your tongue weight will be more than the advertised 600lbs.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
fla-gypsy
North Florida
Posted: 05/04/12 11:07am Link  |  Print  |  Notify Moderator
Forget the 600 lbs dry hitch weight and plan on the neighborhood of a 1000#. Some actual info would help us give some better advice. Like the trailer GVWR and model number.
