Vegas Bob
I have a few light scratches on my class b roadtrek
they are not deep, is their any way to remove them.
Joy
Henderson KY 42420
In the paint or fiberglass or what?
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
johntichy
Get some 3M Super Duty Rubbing Compound. Only can get it at autobody paint supply stores.
steelpony5555
Copperas Cove Texas
Not sure I would use super duty rubbing compound if they are just light scratchs. Have to know what you are doing when using the heavier compounds or you can ruin a paint job real quick. If the scratchs are thru the paint, as you can see a different color of paint in the scratch, there is not a whole lot you can do. Touch up paint may help a little but you will still see it. If the scratch is still the same color as the paint then try a rubbing compound like Turtle Wax sells and they should disappear. If you have lots of scratchs take it to a Paint and Body shop and have them give it a buff job. May cost a couple hundred dollars but they will do a good job making the whole truck look better.
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
big bird 2
La Crescenta, CA
No rubbing compound unless you want to refinish your rig. Get some "Clean and Wax" from Meguiars. Easy to apply and last a long time. About $9.00 for a 14 oz bottle.
Big Bird 2
Here'n'There
I'm NOT suggesting you do this... but it DID work for me....
Mr. Clean "Magic Erasure" - little white sponge looking thing. I had a few minor scratches (not through the paint) on my 5er. I GENTLY, LIGHTLY rubbed the scratched area, maybe 1/2cm on either side as well, GENTLY, LIGHTLY and then followed up with several applications of paste wax rubbed in well.
As I said.. it worked for me but am NOT recommending you try it but if you do - you could easily rub too hard with disastrous results. Well... how disastrous could it really be - we've only talking about a tiny area on a piece of metal! after all.
Here'n'There
2009 Carri-Lite 36SBQ 5th Wheel
2008 Dodge Ram 3500 Quad Cab Long Bed Diesel Dually
On the road with Here'n'There
Role of the C133 in Viet Nam
lots2seeinmyrv
Ocean Springs, MS
I've been using TR3 Resin Glaze, Automobile Cleaner & Polish for over 30 years. Comes in a metal tin can with blue lettering. Wal-Mart or auto parts store has it.
Gets light scratches and road tar off, etc.
2010 Tundra TRD 4x4 Dbl Cab 5.7L V8 4.30 Max Tow 10,300 Payload 1,640 Class IV Hitch 1,030
Prodigy P2 - Blue Ox Sway Pro 10K/1K lbs
2012 Evergreen Ever-lite 29FK
Center Pin
Fort Langley, BC
I'm a big fan of Mirror Glaze Swirl Remover, I use it with a 7" electric polisher and keep it wet with a spray bottle.
Trailer: 07 Tango 299BHS w/ 225/70R15 LT Load Range D
TV: 2004.5 Dodge 610 CTD 3500 QC 48RE 2wd Laramie SRW, FP Gauge, FASS 95/95, Rhino Lining, Hensley Arrow, Air Bags & Compressor, Canopy, Custom Boat Rack.
Been running B100 home brew June 2008!
wandering1
johntichy wrote: Get some 3M Super Duty Rubbing Compound. Only can get it at autobody paint supply stores.
Takes the clear coat off and makes it look worse.
HR
johntichy
big bird 2 wrote: No rubbing compound unless you want to refinish your rig. Get some "Clean and Wax" from Meguiars. Easy to apply and last a long time. About $9.00 for a 14 oz bottle.
You must be joking. Don't know what you are talking about. What do you think is used to rub out cars, boats, ect.? If you want to get scratches out you use a good compound (3M). If you have deep scratches you block sand with 600 wet and then use compound. PERIOD! I have painted 100's of cars.
