RV.Net Open Roads Forum: General RVing Issues: Throwing out a question because...
 > Throwing out a question because...
CincyGus
Cincinnati
Posted: 05/04/12 05:10pm Link  |  Print  |  Notify Moderator
Did a quick search and found this.
Adjustable Folding table leg
Different style than the picture but might work for you.
Good luck in your search for the right conversion.
EDIT*** Thought it would save the correct page for you but link goes back to the main page. It's on page 25, top right corner.
* This post was edited 05/05/12 10:42pm by an administrator/moderator *
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
Ohiojude
Greensburg PA
Posted: 05/04/12 05:21pm Link  |  Print  |  Notify Moderator
Did you try CL? I am always seeing parts, tables and stuff in the RV section. Good Luck in your search.
05 Chevy 3500 LT/Crewcab/duramax diesel/allison, 2012 Raven loaded and always ready
bukhrn
Lanexa, Va
Posted: 05/04/12 07:28pm Link  |  Print  |  Notify Moderator
FunnyCamper wrote:
K Charles wrote:
What you want is right here
K Charles
that is the kind I don't want (thanks for posting that cause I tried to do photo but don't know how)
the unit comes wtih that setup --I was hoping for the other kind.
I thought, thats what they all had, simply lift the table top up, legs come out, top drops down into a bed, nothing hard about it.
2007 Forester 2941DS
2005 KIA Spectra
FunnyCamper
Southeastern
Posted: 05/05/12 02:31am Link  |  Print  |  Notify Moderator
bukhrn wrote:
FunnyCamper wrote:
K Charles
I want a moving table. I don't want fixed. many campers come with a dining table that you can slide, move, use outside. It isn't about making the bed, it is about having the table movable. With a U-shaped dinnette I noticed the movable table is so much nicer to have people slide to the back.
thanks everyone!
falconman
On The Road!!
Posted: 05/05/12 09:33am Link  |  Print  |  Notify Moderator
Ok, give this a try! Midway down the page
http://www.thefind.com/furniture/info-rv-table-legs#page=8&local=0
Chiefcpo
Huntsville, Alabama
Posted: 05/05/12 08:47pm Link  |  Print  |  Notify Moderator
Easy fix was to take the table off the floor pedastial mount them to a 3/4" doubled plate of plywood and finish the surface. You will need to make a wedge for the time it is pulled out from the area abd make it not rock due to the slidout and flooring being diffrent level.
Hope this is what you want will try to get a picture of Tom's modification as it does work whe the 4 meet their for eating or what ever.
Chiefcpo
Huntsville, Alabama
Posted: 05/05/12 08:48pm Link  |  Print  |  Notify Moderator
D.E.Bishop
Eagle Rock, CA
Posted: 05/06/12 08:03am Link  |  Print  |  Notify Moderator
At first it sounded like you wanted a lolding leg but now it seems you want to be able to move the table. In the RV Supply catalog most dealers use is a leg by Hong's that utilizes the pedistal tube but has a movable base. It is Hong's Porta-Leggs. Hope this helps.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
D.E.Bishop
Eagle Rock, CA
Posted: 05/06/12 10:22am Link  |  Print  |  Notify Moderator
Here is a clicky to ebay sale for porta-leggs, it's Hang's, not Hong's.
Clicky
They are $50.49 in the stores.
bondebond
Searcy, AR
Posted: 05/07/12 09:00am Link  |  Print  |  Notify Moderator
FunnyCamper wrote:
bondebond wrote:
If you're trying to add these kind of legs:
then you're going to have a tough time. The very few places I've found were old sites/pages and they don't appear to be publicly available. However, one fellow mentioned that he ordered them through his RV dealer to do just what you're wanting to do (that's where this image came from). You'll notice his two pedestal holes in the floor that he now uses as bungee anchors.
Jeff's mods is where I got this. Maybe contact him directly.
yes that is getting closer to what I want. It is the kind that you flip the lever and it collapses down. I thougth it would be easy to get rid of the alum. fixed legs and change the top onto a collapsable free standing leg unit. hmm...might not be that easy
will probably need to ask someone like camping world if I can do it.
Yes, these fold under. I have had two campers (PUPs) now with this table and folding-leg style. The legs fold up under it like a traditional large folding table you would see used at conventions, churches, etc. There is a velcro strap underneath to keep the legs from unfolding when you're using it as a bed platform. This lets you carry it outside and set up indepently of the camper. I use mine all of the time in the back yard for additional tablespace for eating, parties, etc. It is very stable in all directions, unlike the pedestal set up, which is noticeably harder to set up, take down and manage. If it's not that hard, then the instability of the pedestal makes it useless, at least with my little people.
This space left intentionally.
2006 Fleetwood Sequoia and mods...one of the tallest highwall pop-ups on the planet after flipping the axle.
