TS21sso
North Central Texas
Just purchased a new fiver and want to get a 50 amp surge protector. I have seen the tech data and prices from each of the two manufactures listed above, but would like some input from the user end of these products as to their performance. Thanks
tvman44
Southwest Louisiana
Had a surge guard and never again, Progressive Industries is far superior and has excellent after sales support something the other is seriously lacking.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
MrWizard
Traveling
moved from technology corner
TechWriter
On The Road
The two are a horse a piece. I've seen good & bad written about both so I don't think you can lose with either one.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
TNTraveller
Knoxville, TN
I have never had a surge guard but have had good experience with Progressive 30 amp and 50 amp surge protectors. Not the fancy ones,just the basic circuit tester/surge protector. No under or over voltage protection.
M GO BLUE
Southgate, MI
Whatever you purchase make sure it is multi-function protector that protects your entire RV...if I remember correctly we paid around $300-$350 for the multi-function surge protector we have (50A)...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
dqdick
Council Grove, KS
We had a progressive 50amp surge protector with our TT and it was fine. With our 5er we have the Progressive 50amp EMS. More expensive, but our current rig has too many expensive electrical items to risk high or low voltage park situations.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
falconman
On The Road!!
I have the PI 50 amp hard wired unit with the remote (wired) display and am very happy with the unit and the customer service. After about 3 years it started to develop a humming sound. Called customer service and they gave us some tips on cleaning the contacts. That worked for a short time and another call to customer service resulted in us recieving a new contact board which solved the issue, free of charge.
Wiscampsin
Wisconsin USA
If you're going to do it, do it right - Progressive EMS
2013 Palomino Sabre 34 REQS-6
http://s1340.beta.photobucket.com/user/W........6?&_suid=1357224714962013706578115184365
W4MBG
Williamsburg, VA
X whatever on the progressive.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
