boosTT
Milwaukee
I only need a 1/2 ton (19' travel trailer) and would like a crew cab with somewhat low miles.
Any good suggestions? The 09 ram 1500 seams to be the newest generation that falls within my price range. Any others?
APT
SE Michigan
I highly recommend 2009+ crew cabs. Ram and Ford for their larger rear seat space starting that year. GM and Ford for their 6-spd transmissions starting that year.. And Ram for the improved power for 2009+. For a 19' TT, any of them will do well and the payload limitations of the Ram should not be significant for this TT. Test drive them all and find the one you like best.
2012 VW Passat TDI
bailer6334
Prescott, AZ
As I stated in a thread earlier in todays local paper I see advertised a Dodge 2012 RAM Quad Cab 1500 for $20,880 and a Chevy 2012 Silverado X-Cab for $23,325. Might want to look at new also.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
the bear II
Torrance CA.
The truck of choice seems to be a Ford F150 if you pay attention to what is towing on the highways.
I have always preferred the ride of the chevy trucks. But the Fords seem to be better at towing and stopping.
Try test drive while towing your trailer. Find a test drive route that includes a steep grade to go up & down, curves and some patches of rough road.
bmanning
Phoenix, AZ
APT wrote: I highly recommend 2009+ crew cabs. Ram and Ford for their larger rear seat space starting that year. GM and Ford for their 6-spd transmissions starting that year.. And Ram for the improved power for 2009+. For a 19' TT, any of them will do well and the payload limitations of the Ram should not be significant for this TT. Test drive them all and find the one you like best.
See bolded text.
Everyone will have an opinion on what's better in the 1/2 ton market; Ford, Chevy, Dodge, Nissan Titan, Tundra all have their fanboys and their haters.
The only opinion that matters? Yours
Drive them all, multiple times if necessary...geek it up, make pro/con lists...get your sig other/family's opinion...by doing so you'll very likely never regret your choice.
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
1995brave
San Antonio, TX
Around here a brand new 2012 Dodge Ram 1500 Quad Cab with the "Hemi" is advertised for $22,995 at dealerships.
danojeno
Corona, CA
03-06 F350 Diesel Dually Just Kidding! Don't forget about the Tundra...Many love them.
2006 Chevy 2500HD 8.1 4x4 CCSB
2012 Eclipse Stellar 28SBG, Spring Over Axle
YamaDooed
Upstream from the herd...
1st generation double cab Tundra 4x4 is what I'd recommend in that price range.
NewsW
US
danojeno wrote: 03-06 F350 Diesel Dually  Just Kidding! Don't forget about the Tundra...Many love them.
I would buy a perfectly clean, 1 owner, never modded, low mileage, documented maintenance 6.0 03 to 08 F series anytime.
For the right price.
As for the Tundra, you get this feature for free:
http://www.youtube.com/watch?v=1j3PWGRrCZ4
35 seconds into video.
Trying to buy a truck on a budget involve many compromises, and uncovering bargains where others haven't got there first.
The perfect used truck, with the perfect rep.. is going to cost you.
An excellent truck with a bad rep that need not apply to that particular unit is your best deal --- any make, model.
Ron3rd
Upland, CA USA
boosTT wrote: I only need a 1/2 ton (19' travel trailer) and would like a crew cab with somewhat low miles.
I would go with either an '07 or later Tundra with the 5.7 and 6 speed, a Titan, or any of the offerings from the Big 3 that are new generation with the 6 speed trans. Any of those will work fine for you. Lot of good choices abound in the 1/2 ton market.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
