fish58
florida
My 2004 Chevy Silverado 3500 gets only 12 mpg without towing and i drive like a nun.After doing some reading it turns out, it appears the the turbo inlet tube is restricted due to a necessary bend from the manufac. AFE makes an after market tube that supposedly allows 73% more airflow. Has anyone ever replaced this tube and were you successful in bumping up your mpg? Also, if anyone has added a chip to my model & year, what brand and how much improvement did it make? Any other suggestions to increase my mpg, I would love to hear some recommendations.
donn0128
Pronounced Ore-gun
When I had a LLY I saw close to 20 non towing. I suspect you have injector issues. Fix that and your milage should go up a lot.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
bartlettj
Forest Grove, OR
More airflow doesn't usually increase MPG, in fact it often hurts it because it allows the engine to make more power. It sounds like you probably do need a fuel injector repair.
bob213
Fresno, CA
I replaced mine. Not for mileage but for turbo and engine cooling. Really did not see an increase in fuel mileage. Mine was an 05'. I agree that you may have other issues.
JKrussow
Alabama
I have the AFE turbo mouthpiece and a Bank IQ system. The mouthpiece improved mileage a little but if you are expecting to go from 12 mpg to say 20 mpg it's not going to happen. I got the mouthpiece as part of my plan to lower incoming air temps to prevent overheating. If you have been seeing the 12 mpg for quite a while (1000s of miles) then it may be the truck. But if the mileage has just started to suffer I would look into Donn's suggestion and have the injectors tested.
I get 11 to 13 mpg towing and 15 to 17 empty. Banks system is set for economy when empty and to power level 4 when towing. Either way I do try and set speed records with; I'm driving no faster than 60 mph towing and 65 empty.
John & Rana
Toby "da bear" RIP 12/28/12
Bandit, Kato & Punkin
2004 GMC Sierra 3500 D/A DRW CC, Banks IQ w/Econominder, Speedbrake & CAI, Curt Q5 20K
2011 Heartland Big Country 3650RL
the bear II
Torrance CA.
You may find some help at www.dieselplace.com
Look for the forum aimed at duramax engines or Chevy light trucks.
ScottG
Bothell Wa.
I'm curious, do you have to crank the starter longer now than you used to? That's one of the early signs of injector problems.
Scott, Grace and Wesly
H0NDA eu2000i
Turtle n Peeps
California
donn0128 wrote: When I had a LLY I saw close to 20 non towing. I suspect you have injector issues. Fix that and your milage should go up a lot.
^^^ This.
outside the fire"
NewsW
US
Need more specifics, mileage, maintenance, etc.
If it is a DRW, 12mpg may not be that unusual.
Winter fuel and cold weather use also gets a lot less mileage.
M GO BLUE
Southgate, MI
My 2005 I still get 18-19 non-towing....
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
