BigSur2
Hampton, VA
Guys....I know this subject has been beat to death, and frankly, I just don't have time to research it. Very busy day and I wanted to get this out there.
Best to get to the point. If I am no more than 1" unlevel from side to side on my TT, is that TOO unlevel for my fridge? Long story short, I pulled in earlier today....was off a little bit. I blocked up about 1" and then was slightly unlevel the other direction. Bottom line I decided to take the blocks out. Knowing what I know, I am about 1" out from one side of my TT to the other. Is that even enough to worry about? When IS it too much to worry about? My fridge manual talks in terms of degrees; I don't know how to convert that in a practical manner.
Any help is appreciated.
BigSur2
2012 Keystone Bullet 286QBS
2006 Ford F150 5.4 V8
the bear II
Torrance CA.
1 inch won't be a problem. I've been over 5 inches side to side for three days without an issue.
dahkota
Washington, DC
I don't think my tt has ever been level. The fridge won't start if one side of the tt is up on a curb but, if it's already running, 5-6" doesn't seem to make a difference.
2008 Ford F250 diesel
2013 Keystone Sprinter 277RLS
skipnchar
Topeka or somewhere else
Doubt if it will cause you any problems but the closer to level the better. As a general rule if it's not uncomfortable to live in it's level enough but since it relates to the circulation of the coolant, I generally get pretty close to level
CloudDriver
New Jersey Shore
I calculated the max allowed for our wheelbase based on the Norcold specs. Turned out to be 7 inches front to back and side to side. That's too much slope for us to be comfortable living inside. We find we are comfortable being no more than 3 inches out of level so that's our limit. Good for the fridge too.
2003 Winnebago Minnie 24F - Ford E-450
Helimech
Chino Valley
Leveling the trailer is more for the DW. Never had a problem with the fridge.
firemedic08
North Central PA
Your Suposed to level? LOL
Donnie
1994 Chevy 2500 Extended cab
1980 sunline,
old guy
Oregon (pronounced Or e gun)
I have done the same this you did, the one inch doesn't make that much difference. one thing I don't do is did a trench on the other set of tires to try to level. If I have to go to that extreme, I will move my camp site.
AtomicChicken
Central Louisiana
As previously said that's not enough to hurt it. Most of the time if I'm only 1" off on either side I leave it be. More than that though and I'll break out the boards.
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
fla-gypsy
North Florida
If it looks and feels level, it's good enough
