I use Amsoil. Per Amsoil website: SERVICE LIFE
Recommended for 50,000 miles in severe service* and 100,000 miles in normal service;* or per vehicle manufacturer-recommended intervals, whichever is longer.
*As defined by vehicle or transmission manufacturer
X2 on getting your fluid tested if you think you need to change it.
If you are still under warranty I would follow what Allison recommends for their service intervals. I would also not use Amsoil, which is not an approved replacement for Transynd oil. It may work just fine but since it is not approved by Allison, why take a chance with your warranty? If your transmission is out of warranty, then service intervals, and fluid choices, are all your choice and responsibility.
rgatijnet1 wrote: If you are still under warranty I would follow what Allison recommends for their service intervals. I would also not use Amsoil, which is not an approved replacement for Transynd oil. It may work just fine but since it is not approved by Allison, why take a chance with your warranty? If your transmission is out of warranty, then service intervals, and fluid choices, are all your choice and responsibility.
I agree. Allison has a list of approved "Transynd-like" products. Choose from one of the approved fluids.
