RV.Net Open Roads Forum: Class C Motorhomes: Smoked The Converter
 > Smoked The Converter
kcgaz
Scottsdale, Arizona
Posted: 05/04/12 09:18pm Link  |  Print  |  Notify Moderator
smkettner wrote:
Well you better hope it is just the converter.
Did he hook you up to two breakers at the main panel (240v)?
Yes he did hook it up to two breakers, I am presuming that he should have only hooked it up to one breaker?
God Bless,
Kevin & Tracy
1993 Fleetwood Tioga Arrow, 30', Ford 460...Still on the road!
My Blog
smkettner
Posted: 05/04/12 09:27pm Link  |  Print  |  Notify Moderator
Yes, move one "hot" off the breaker and over to the neutral bus for proper 120v service.
http://www.myrv.us/electric/
Click top left for 30a service
Also check that he used #10 wire and no more than 30a breaker before something else lets the smoke out.
675 watts solar
Dune Hauler
Cornell, California
Posted: 05/04/12 09:28pm Link  |  Print  |  Notify Moderator
Disconnect the converter or turn off the breaker in the coach feeding the converter before you test on the generator. Always check your voltages ,hot ,neutral and ground before plugging in even at RV parks, you would be amazed at the number of people that repair stuff that have no knowledge of AC power.
The Dune Box
PUCampin
Castaic
Posted: 05/04/12 09:30pm Link  |  Print  |  Notify Moderator
You can bypass the converter, just flip off the breaker in the MoHo for the converter. Plugging in to shore power will still power all 120v items and receptacles.
Yes, one 30A single pole breaker. The cable must also be at least 10AWG with a hot, neutral, and ground. If he ran 12AWG then the biggest breaker you can use is 20A.
2007 Expedition EL 4x4 Tow pkg
1981 Palomino Pony, the PopUp (Sold)
2006 Pioneer 180CK (No more PUcampin!)
Me DW and the 3 in 3
DD 2006, DS 2007, DD 2008
kcgaz
Scottsdale, Arizona
Posted: 05/04/12 09:55pm Link  |  Print  |  Notify Moderator
How do you bypass the converter? When I hook up shore power the converter continues to smoke.
2oldman
Winchester WA
Posted: 05/04/12 10:03pm Link  |  Print  |  Notify Moderator
kcgaz wrote:
, he said that it was testing out at 240 volts when he hooked it up.
And he thought that was ok, and didn't bother to tell you !????
Dune Hauler
Cornell, California
Posted: 05/04/12 10:22pm Link  |  Print  |  Notify Moderator
With no ac power connected or generator running remove the breaker cover plate, look for the wire coming from your inverter connected to one of your breakers. Loosen the terminal screw and disconnect the wire and tape it out of the way for testing, or until you replace your converter. Re-secure any other wire that shared the same terminal.
j-d
Sunny Florida USA
Posted: 05/05/12 05:27am Link  |  Print  |  Notify Moderator
I wasn't through the first sentence when I knew what happened. Many members in this Club. Skills range from Clueless to Licensed Professional. They just look at that massive plug, the heavy shore tie cable, and think it's 240.
Lord Willing, the Converter's the only casualty and the breakers protected the rest.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
skipnchar
Topeka or somewhere else
Posted: 05/05/12 06:26am Link  |  Print  |  Notify Moderator
When folks know nothing about RVs they often will install a 240 volt dryer plug (which looks a little bit like a 30 amp RV plug and the result will ALWAYS be smoke. You probably fried anything in your converter and power distribution box that did not have over voltage protection.
Friends are the WORST people to install those plugs because they are trying to help and THINK they know what they're doing but don't.
NewsW
US
Posted: 05/05/12 07:01am Link  |  Print  |  Notify Moderator
On this site (not necessarily this sub-forum), I had to fight pitch battles to get people to to use licensed propane techs, electricians, plumbers, RV techs (low voltage), etc. to do what I know to be safety critical repairs.
In another sub-forum, posters felt it OK to hurl insults because I made it clear that lead acid flooded cell batteries must be ventilated in accordance with industry standard rules to prevent the risk of hydrogen explosions and acid spills!!!! The fella was going to put the lead acid batteries in an enclosed compartment!!!
Having watched fires (in real time) in RVs, cars and trucks, and how fast an RV can be engulfed in flames and trapping those inside, and knowing what I know about what vibration and corrosion can do to an RV's electrical, plumbing and propane / fuel systems, I prefer to never mess around.
Now for this case....
IMHO, the entire electrical system has to be inspected and re-certified to make sure there is no hidden damage.
Because of hidden wiring, such an inspection cannot be perfect but can still lead to hidden flaws being missed unless the entire system is rewired from scratch.
There is no factual basis to believe damage is limited to the converter and specifically to the capacitors.
Circuit board, etc. where you cannot see --- all are likely toast.
In any case, after an incident, the entire device have to be replaced as it is not "field repairable" unless you are a certified electronics tech and know what to watch / look for ---- far cheaper to buy a new converter.
Without knowing how the power went into the circuit, and whether there are things like hidden cabling that is melted, arced, etc. etc.
Every appliance need to be disconnected from the mains, and re-certified.
Licensed electrician is the way to go.
Licensed RV electrician is a specialty is the real good way to go.
I would not turn on any power, 12V DC or 120/240!!! AC until every last circuit and appliance and switch and plug is inspected.
* This post was edited 05/05/12 07:29am by NewsW *
