RV.Net Open Roads Forum: Tow Vehicles: finally switched to diesel...
Search only in Tow Vehicles
 > finally switched to diesel...
Billieg2
Gone from this forum
Posted: 05/05/12 12:20pm Link  |  Print  |  Notify Moderator
FishOnOne wrote:
Congrats.... I'm sure you won't be dissapointed with it's towing ability. The problems with the 6.0 psd are now well understood and with some simple steps taken can lead to many trouble free miles.
1. Use only Motorcraft oil and fuel filters (No aftermarket filters... period!)
2. Go to a Ford dealer and have the latest flash installed on the truck (cost is ~ $100). This flash will monitor your engine oil temperature (EOT) and your engine coolant temperature (ECT) differential.
3. Change oil every 5k miles using ONLY Motorcraft oil filters and CJ4 API rated diesel oil. If you live in a cold climate you may consider using a 5w40 synthetic oil.
4. Change fuel filters every 15k miles using ONLY Motorcraft fuel filters.
5. Don't let your batteries get weak to the point the truck will barely start. Weak batteries can kill the FICM module.
6. Add a coolant filter (optional). Very cheap and innexpensive modification. (i.e. Sinister coolant filter)
7. It's time to change your coolant using a Ford approved coolant if it hasn't already been done. I use Ford Gold coolant for the record every 50k miles and distilled water.
7. Enjoy many years of service from your truck.
If he has a 2005 he has a 6.0.
I agree with everything but the Ford coolant. That is what plugs up the oil cooler and blows head gaskets.
Drain and refill your coolant with Cat ELC coolant and add that coolant filter. If you can, get rid of the EGR system. A delete kit will cost around $120 and another $200 to delete it. Money well spent.
I also strongly agree with using only Motorcraft filters. They have a patent on the design and ony they will totally filter your oil.
Also, get a Scanguage II and set it to monitor the oil, water and trans temps. Very important. The dummy gauges will only tell you when its ready to blow.
I have a 2007 6.0 and have spent hundreds of hours on diesel forums to try and over come the 6.0 problems. My truck now has 186,000 miles and runs like new. Good luck!
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
larry barnhart
wenatchee. wa usa
Posted: 05/05/12 12:21pm Link  |  Print  |  Notify Moderator
ReneeG wrote:
The OP says he has a 6.7? Why all the talk about 6.0?
6.7 was not made in 2005.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Turtle n Peeps
California
Posted: 05/05/12 12:47pm Link  |  Print  |  Notify Moderator
45Ricochet wrote:
ib516 wrote:
NewsW wrote:
The B50 design life of the 6.0 properly maintained and not modded is north of 350,000miles.
BS
I think he is talking about the VT365
Congrats OP
Guppy covered it really well. Keep up the service.
The coolant filter Mod is also sound advice.
Sounds like another $200 no proof oil change to me. At least the walls of text are gone!
outside the fire"
MackinawMan
NW Ohio
Posted: 05/05/12 01:27pm Link  |  Print  |  Notify Moderator
LOL @ the Dodge people....
2000 Ford F350 XLT 7.3L PowerStroke Diesel CC 4x4 OffRoad SRW Long Bed
2008 Jayco Eagle 314BHDS (Momma Eagle)
Equalizer Hitch System (1400/14000lbs)
Prodigy Brake Controller
Curt XD Class V Receiver Hitch (1500/15000 lb)
45Ricochet
North Idaho
Posted: 05/05/12 02:02pm Link  |  Print  |  Notify Moderator
You mean LOL @ the ex Ford people
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
camping man
Central Fla.
Posted: 05/05/12 02:12pm Link  |  Print  |  Notify Moderator
Congrats on the truck, just maintain and enjoy!
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
nylyon
Putnam County, NY
Posted: 05/05/12 02:54pm Link  |  Print  |  Notify Moderator
Congrats on the truck. As for the coolant question, I wrote a little document on flushing the cooling system in the 6.0. I tried to explain as best that I can what is happening with the 6.0 and the cooling system, and tried to dispel some of the myths about it as well. It's really critical to keep the cooling system maintained regardless of coolant used. I have switched to ELC and have had VERY positive results. In any event, you need to flush the cooling system, reverse flush the oil cooler (it's not hard) and enjoy!
6.0 Powerstroke Cooling System Flush document
Karl, Liz, 3-kids and Stout the wonder dog
2011 Jayco Eagle Super Lite 30.5 BHLT
2003 F-250 FX4 6.0 Powerstroke
ReneeG
Meridian, Idaho
Posted: 05/05/12 02:55pm Link  |  Print  |  Notify Moderator
Ok - I'll be brief - have a co-worker with a 6.0 Ford diesel - he knows of the issues out there but has never had a problem with his.
2011 Bighorn 3055RL
2011 F350 SD CC DRW 6.7L Diesel Lariat, Hensley BD3 with Ford Under-Bed Adaptor
Dave & Renee plus (Champ, Molly, and Paris in spirit), Missy, Maggie, and now Mica!
FishOnOne
Katy
Posted: 05/05/12 03:01pm Link  |  Print  |  Notify Moderator
LOL @ the "Fiat Boys"...
Can you say VM Motori... hint...hint!
Jarlaxle
New England
Posted: 05/05/12 03:04pm Link  |  Print  |  Notify Moderator
Some people loved their Yugos, too.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
