paullac
Cincinnati, OH
2012 Sunseekers have the following tank sizes:
fresh - 44
gray - 30
black - 30
2012.5 & 2013 Sunseekers have the following tank sizes:
fresh - 44
gray - 39
black - 39
I'm concerned about the gray tank size. We do state parks (i.e., no hookups) on weekends. I figure I can make 39 gallons work for our family of 4 but 30 gallons won't work. Isn't a 30 gallon gray tank too small for a 44 gallon fresh tank? Or am I missing something in how the tanks work.
'13 Forest River Sunseeker 3100
'04 Fleetwood Sedona / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar
NewsW
US
The tank capacity is ample with reasonable conservation efforts that one normally practice in an RV.
If anything, you are going to run out of fresh water before anything else.
Combined capacity of black and grey is way above the fresh water capacity.
A fair amount will be used for black / flushing of toilets.
Grey is kitchen / shower water.
In the worse case and emergency, grey water can be released with only minimal hazards as long as there is not dangerous stuff in the water.
Back of the envelope it...
No. of gallons per shower, X persons X days.
Amount used for wash / kitchen..
robsouth
Near Atlanta, GA
If you are very conservative with water use, you should be ok for one weekend. If not, then you will have to go to the dump station and dump. You could get a "blue tote" to dump grey water into, and just take that to the dump station. Good luck.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
downtheroad
Pacific Northwest
You have a total of 60 gallons of waste water capacity... they are assuming that you will dump a portion of your 44 fresh into the black tank also..
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
bukhrn
Lanexa, Va
If you are using State or National Park CG's, you can save a lot of grey water space by using the CG showers.
When we stay somewhere without hookups, the grey will fill at least twice as fast as the black.
2007 Forester 2941DS
2005 KIA Spectra
tenbear
Northern Vermont, USA
When you do the dishes use a basin and dump the water in the toilet. My bathroom sink is plumbed into the black tank, maybe yours is too? That helps a lot.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
fla-gypsy
North Florida
RV makers don't seem to have a clue about what is needed for gray water capacity vs black water.
crawford
Dandridge Tenn.
Remember a lot of bath rooms are hook to black tank. To check that run your bath room sink see which tanks is filling. My slide has kitchen sink is also hook to black tank. So to be sure check you may be surprised I was.
ron.dittmer
Northern Illinois
Our motor home has....
41 fresh
35 black
23 gray
Admittedly it's not ideal, but it was interesting when we picked up our rig from the factory. During the run-down & inspection, we were advised the gray will likely fill up before we were ready to dump. We were instructed by the motor home manufacture to feel free to blend the two tanks when the gray fills up. And so we do so quickly and simply which is kind of nice to flood the black tank with soapy wash water for a cleaner black tank draining. So there is a bright side to the inconvenience.
I don't know if blending tanks is something all motor homes can do without creating a mess during dumping, but our Sani-Con system here makes tank blending clean and simple.
Other floor plans of our particular brand motor home has the black and gray switched. It has to do with the standard mounting of the two waste tanks behind the rear axle, and the relative positions of the plumbing fixtures. Our toilet happened to be right above the larger tank, so there we have it so.
I wouldn't want any other drain going to the black tank for fear that toilet water could back up. Worst case scenerio would be having poop water back up into your shower pan.
edited 05/05/12 09:10pm by ron.dittmer *
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
hotbyte
Barnesville GA
Do conservative navy showers (use on/off button on shower nozzle), the basin in sink to dump into toilet, stay aware of what you are using (turn off sink when brushing teeth, between rinsing dishing, when washing hands, etc) and you should be OK. Since we don't use a toad, I keep our campsite setup easy to break in case I need to go somewhere in motorhome. If needed, a quick trip to dump station isn't much of an issue or stop by when coming back in park after a trip to store, etc. Some state parks here in GA have gray water dump areas around the loop. They are basically buried trashcans filled with gravel and hardware wire over the top. They do have signs saying "Gray Water Only." I've gotten a site next to one of those before and using a non-drinking water hose and sewer cap with hose bib fitting drained gray tank.
Our Web Albums Temporary Web Albums
2006 Yellowstone SE, 1998 Dodge Durango SLT 5.2L and 2011 Tidewater 1900 Bay Max
