RV.Net Open Roads Forum: Class A Motorhomes: Dynamat
Kiwi_too
Western, WA
Posted: 05/05/12 09:44am Link  |  Print  |  Notify Moderator
Happy 2,
Thanks. I believe this is The Dynamat what you are referring to. Correct? I have been looking at that. I have carpet in front of the slide, to the firewall. How did you get it under the carpet? I have not tackled it because I was unsure of how to install it between carpet and floor. What adhesive did you use on the doghouse?
I am somewhat handy with tools, though far from great. With some advice, I can probably do this myself.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
MountainAir05
New Mexico
Posted: 05/05/12 11:05am Link  |  Print  |  Notify Moderator
I unstall mine under the dog hose. It has a stickey back or if you are just installing under the carpet, just slide it where you want it. It is made to self glue to the metal on door, trunk, hood, to deading out the sound.
Fishinghat
Western Washington, USA
Posted: 05/05/12 11:14am Link  |  Print  |  Notify Moderator
Never used the stuff, but I did buy some lead foil from Boeing surplus to insulate my engine room of my boat. I'm going to assume this product is similar. To work correctly, it has to completely cover the source of the noise, just like rolling up a window tightly to seal out the outside noise. It works because lead is very dense and doesn't transmit vibrations (noise) well. I used a spray adhesive.
So, I'd remove the carpet, glue or somehow attach the product to the dog house and then reapply the carpet. You may find it more convenient to screw down the carpet.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
Weathertodd221
FL
Posted: 05/05/12 12:14pm Link  |  Print  |  Notify Moderator
I removed the carpet on my p30 chassis. It had a step so it was pretty easy. Took about 60 sq ft of material to do the cab area. I removed the seats as well.
Kiwi_too
Western, WA
Posted: 05/05/12 09:02pm Link  |  Print  |  Notify Moderator
How hard is it to lift the carpet and then reinstall. I know I will have to remove the driver and passenger seats.
Weathertodd221
FL
Posted: 05/05/12 09:09pm Link  |  Print  |  Notify Moderator
Not worth it to reuse it. A good carpet guy thats done motorhome before shouldnt charge more than $150 for new carpet & install.
happy-2
calif
Posted: 05/06/12 12:04am Link  |  Print  |  Notify Moderator
kiwi too,I DIDNT PUT IT UNDER THE CARPET. I cut to fit it under the floor of the engine compartment, and under the motor cover,or doghouse,it has a stickey side,and i used a tennis ball to smooth it out.it cut down on the noise and the heat is none exsistant.
Weathertodd221
FL
Posted: 05/06/12 07:38am Link  |  Print  |  Notify Moderator
simply insulating the doghouse will cut some noise but not all of it.
Average dog house is what? 6 sq ft? Average passenger area is 16.
Kiwi_too
Western, WA
Posted: 05/06/12 07:00pm Link  |  Print  |  Notify Moderator
OK. I am gonna get under Aurora and have a look. Did you use anything special to clean before attaching.
Tennis ball, eh. Neat trick to "roll" it into place.
Kiwi_too
Western, WA
Posted: 05/06/12 07:04pm Link  |  Print  |  Notify Moderator
$150 seems very cheap. I suppose this involves me removing bolted down chairs and removing the carpet, which I am willing to do. I will have to price carpet and pad locally and do some research on installers.
