RV.Net Open Roads Forum: Beginning RVing: wdh setup question
 > wdh setup question
mastertinner
two rivers
Posted: 05/05/12 10:01am Link  |  Print  |  Notify Moderator
Hey everyone I'm new to rving and need a little help with my equalizer hitch. First off my hitch has the 1000 lb bars, and their is 5 washers installed. My loaded tongue weight is about 1000 lbs.
The hitch transfered about 200lbs back to the tt axles, 900lbs to my tv drive axle and lightened the steer axle up 100lbs.
I would like to take a little more weight off the drive axle. It is getting close to the rear axle load limit and my gvwr, but not over.
My question is how wuch does adding washers help to distribute weight? Would adding 2 washers transfer another 100 lbs between the steer axle and tt axles or would I need heavier bars? The dealer told me that its fine and dont worry about it. Seemed like they were pushing me out to get the next guy ready to load up.
Do you guys think my setup is fine or would it be a good idea to transfer a little more weight?
Thanks mastertinner
planter8
Utica, MI
Posted: 05/05/12 12:43pm Link  |  Print  |  Notify Moderator
The idea is to transfer weight off of the rear and onto the front. Something isn't right. Is the tv nearl level when loaded?
Planter8
Sunset Trail ST30BH
Ford Econoline E-150 wagon 5.4L V8 3.55 axle
Equal-I-zer hitch
Chuck&Gail
In the Colorado Mountains
Posted: 05/05/12 04:31pm Link  |  Print  |  Notify Moderator
I'd add one more washer, and reweigh. If still close, add another washer. Increasing bar size is NOT the answer if your tongue weight really is under 1000#.
Just for interest our Equalizer has 7 washers in it. Yes, I want my front TV axle weight to INCREASE, at least slightly, and my rear GAWR to not be exceeded. Works for us.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
mastertinner
two rivers
Posted: 05/05/12 07:59pm Link  |  Print  |  Notify Moderator
Thanks for the responses guys. The rear of the tv dropped about an inch to an 1 1/4" and the front of the tv stayed about the same.
Chuck&Gail I will try adding washers. Do you know how much adjustment a washer gives?
Chuck&Gail
Posted: 05/05/12 08:55pm Link  |  Print  |  Notify Moderator
Sorry, good question, I didn't keep previous numbers on weights. I DO know I add washers until front and rear of TV drop by about the same amount. Only a bit more drop in rear. Some say that method is no longer valid, but it has worked great for me for over 100,000 miles with my Equalizer so I use it.
mastertinner
two rivers
Posted: 05/05/12 09:31pm Link  |  Print  |  Notify Moderator
Yah, I've bin kind of seeing that trend too. Seems like alot of manufacturers are recommending the steer axle be a bit lighter when hooked up. To me that doesn't make much sense. I think I'm going to try and get the weight back to stock or maybe 50 lbs or so heavier than stock.
