RV.Net Open Roads Forum: Class C Motorhomes: Metal roof crack
 > Metal roof crack
cudabob
Ont Canada
Posted: 05/05/12 10:08am Link  |  Print  |  Notify Moderator
My 89 Mallard Sprinter 25 ft C has a small split in the roof.It looks like the material is galvanized metal.Last summer this split appeared and I put some flexable roof sealer on it and the leak stopped but this year the leak is back.It looks like the sealer has maybe shrunk and split and I have a small leak again.Is there a permanent fix for this?
fordsooperdooty
Posted: 05/05/12 10:18am Link  |  Print  |  Notify Moderator
It's more likely aluminum...use a strip of Eternabond Tape..it's flexible and has extremley good bonding ability. You might drill a small hole at the beginning of the crack to relieve pressure.
johntichy
Posted: 05/05/12 10:34am Link  |  Print  |  Notify Moderator
Did you stop drill the crack so it does not get bigger? If not, you should get a very small drill and put a drill hole at the very end of the crack. That will stop it from spreading.
pbitschura
SE MN
Posted: 05/05/12 05:35pm Link  |  Print  |  Notify Moderator
For a little more umph you could cut a piece of aluminum .024 stock as a patch. Circle the crack with butyl, bed the patch in the butyl, then cover the seam with eternabond.
1988 Mallard class c 24' Chevy chassis 350 cu gas.
Dusty R
Charlotte Michigan 48813
Posted: 05/05/12 05:19pm Link  |  Print  |  Notify Moderator
We had an '88 Mallard. It had an aluminum roof.
phillyg
Front Royal, VA
Posted: 05/06/12 07:29am Link  |  Print  |  Notify Moderator
Had aluminum roof in an old Mallard, too. It will expand/contract a bit and no simple patch will work. An aluminum patch, caulked with an appropriate material for aluminum, fastened mechanically with pop-rivets, and Eternabond over should fix permanently.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
cudabob
Ont Canada
Posted: 05/07/12 02:38am Link  |  Print  |  Notify Moderator
thanks
oldtrucker63
Harlan Kentucky
Posted: 05/07/12 05:09am Link  |  Print  |  Notify Moderator
cudabob wrote:
thanks
X two here, The best fix is the fight way to do it, Patch it and never worry again.
Without Trucks,....America Stop's
 > Metal roof crack
