teach515
Land O Lakes
I would like to clean the vents and install an airmaxx vent cover on my TT. However, this would require me to walk on my rubber roof. Is there a safe way to do this and not put a hole in the roof. Thanks.
fordsooperdooty
I crawl on hands and knees...for one reason I hate heights, the other reason is to help distribute my weight. Most if not all RV Builders state the roofs are "waklable" however.
larry barnhart
wenatchee. wa usa
I guess it depends on the roof's construction but our alpenlite has a roof that feels like it is concrete. No soft spots so learn where you can walk or have a plywood with carpet under the plywood and do what is needed to do.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
westend
all over
I'm about to use 1/2" foam carpet pad and plywood, if you don't hear back from me.....
'03 F-250 4x4 CC
Jayco-noslide
Galesburg,Il., USA
I don't take any special precautions walking all over our small 5th wheel but then I weigh 155 and must admit it doesn't feel all that indestructable.
Jayco-noslide
smkettner
Just regular tennis shoes. I would not use anything that might contribute to tripping or slipping. Primary concern should be your safety... not the roof. Use a tool belt to carry stuff.
675 watts solar
rgolding
Southern Illinois
I've been on the roof of my our 2010 Dutchmen 25C-GS quite a bit lately. I've been installing "Dicor" tape over all areas covered with the "Dicor" caulk and checking for any cracks in the caulking or areas that look like they are wearing like under the Winegard Antenna and on then along all the edges of the EDPM roof. I would suggest you clean the roof with a mild soap like Murphy Oil Soap to remove any grit and then kneel on a pad to not grind any grit into the surface. As others have said, your safety is the most important.
edited 06/06/12 06:42am by rgolding *
ReneeG
Meridian, Idaho
As noted, wear good non-slip shoes and watch where you step at all times, DH accidentally stepped on one of the vents and cracked it. Up there is where you don't want to suddenly step back, not knowing exactly where you are!
2011 Bighorn 3055RL
2011 F350 SD CC DRW 6.7L Diesel Lariat, Hensley BD3 with Ford Under-Bed Adaptor
Dave & Renee plus (Champ, Molly, and Paris in spirit), Missy, Maggie, and now Mica!
dalehelman
Liberty Lake (Spokane) Wa.
Not all TT have roofs are designed to walk on. If it does not have a ladder it may not support foot traffic. It is very common in the newer light weight TT. I bought a 2'x4' 2 inch thick sheet of foam insulation from Home Depot. That way the weight was distributed more evenly over a larger area.
Dale & Sandi
2006 Jeep TJ 4.0 w/33s 4" lift
2008 Winnabago Adventurer 38T
Liberty Lake (Spokane) WA.
DIY Manual replacement for Workhorse Auto Park emergency brake.
Stay In Play Duo Toad Braking System
hallock5
Tennis shoes, not golf shoes
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
