RV.Net Open Roads Forum: Technology Corner: Digital TV - VHF vs. UHF
 > Digital TV - VHF vs. UHF
Big Love
SF Bay Area, CA
Posted: 05/05/12 01:32pm Link  |  Print  |  Notify Moderator
I am curious about the effect of the Winegard Wingman on VHF Digital TV signal reception. I know that the Wingman enhances UHF digital reception, but does it also degrade VHF digital reception by changing the characteristics of the Winegard Sensar antenna?
I note that with the Wingman attached, I do get better UHF reception, but I do not seem to be getting any VHF digital stations even though they are nearby.
Johno02
Lexington, TN USA
Posted: 05/05/12 02:03pm Link  |  Print  |  Notify Moderator
Should have no effect ot VHF, whenever you find one. With a new Sensar IV head, I did see that normal rotation had the same effect on reception as before. However, I do find several VHF stations that seem to have no broadcasting, other than a signal.
Noel and Betty Johnson
2005 GulfStream Ultra Supreme, 1 wife, 1 Poodle
camperpaul
Wherever I park my travel trailer
Posted: 05/05/12 02:29pm Link  |  Print  |  Notify Moderator
Quite a few of the old VHF channels are now in use by communications services and you will see them as a 'signal' with no video when you do a scan with your TV set.
To see the TV stations in your area, go to: The FCC website and enter your location or Zip Code.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
burlmart
Baton Rouge
Posted: 05/05/12 03:33pm Link  |  Print  |  Notify Moderator
I may have accidentally found a solution for your VHF-loss w/ wingman. Do your scan at night or early dawn.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26018222/gotomsg/26028687.cfm#26028687
On first installing wingman, I also lost the analogs.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26018222/gotomsg/26027346.cfm#26027346
2005 Trail Lite 213 B-Plus w/ 6.0 Chevy
burlmart
Baton Rouge
Posted: 05/05/12 03:40pm Link  |  Print  |  Notify Moderator
Unless it was the metal roof that caused the two analogs to show up this morning???
SCVJeff
Santa Clarita, CA.
Posted: 05/05/12 06:44pm Link  |  Print  |  Notify Moderator
The Wingman has absolutely no effect whatsoever on VHF channels. what you don't have now, you didn't have before..
Jeff - WA6EQU
Wherever I happen to park
Posted: 05/06/12 06:32pm Link  |  Print  |  Notify Moderator
Wingman will not affect VHF so as you'd notice.
Though the idea was to get rid of VHF tv, and move everyone to UHF, And then REsell the VHF spectrum, and bids were indeed taken on that.. I have seen Digital Stations as low as Channel 5 on the frequency chart Chan 5 is not only VHF, but it's VHF-Low band (2-6) Oh well, The best layed plans of Men and Government Agencies I guess.
SCVJeff
Santa Clarita, CA.
Posted: 05/06/12 08:20pm Link  |  Print  |  Notify Moderator
There are a few even lower than that.... Go figure. Since there is another repacking coming I suspect the stragglers will be pulled into the frey
Big Love
SF Bay Area, CA
Posted: 05/07/12 07:50am Link  |  Print  |  Notify Moderator
Thanks for the info. After a little more investigation, I found that the VHF digital stations in my area are broadcasting at lower power ratings than the UHF stations which are well received and transmitting at higher power.
It seems my inability to receive the VHF station 45 miles away (with hills) is related to low station transmit power, not the fault of Winegard antenna with amplified Wingman.
Posted: 05/07/12 09:47am Link  |  Print  |  Notify Moderator
They did drop power when we went digital.. That said...
As a Ham Radio operator I have my "Main" Station in the RV, it is a Kenwood TS-2000, 100 watts on HF and VHF, less on UHF and I did not order it with the Microwave option. (But if I did it would be less still).
ON VOICE (Analog) I can talk to most of the Contential US on 100 watts on a good day, about half the country on an average day.
Switching to Digital (PSK-31) I have done about half the world. But I'm only pushing 25-40 watts.
Think about that some time, Same radio (Exactly) Same antenna (100' long wire) only difference is I do the listening with my ears or the computer uses it's "ears" and translates.
