RV.Net Open Roads Forum: Better to have the hitch too high or too low?
 > Better to have the hitch too high or too low?
ZZSPIRAL1
CARSON CITY
Posted: 05/05/12 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
I can't get the hitch ball level with the trailer. I have a choice, the hitch will be either 1/4" too high or 1/4" too low. In other words, is it better to tilt the trailer up 1/4" or down 1/4"?
Note: I use a weight distribution hitch.
Thank you
handye9
Park City, IL 60085
Posted: 05/05/12 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think 1/4" is that far off, but, given a choice, I would tilt trailer nose down 1/4".
Check out my mods
08 F250 Crewcab,4X4, SB
5.4, 4.10 gears
Flowmaster exhaust, SCT tuner
12 Flagstaff 831FKBSS (TT) and 00 Maverick 8801 (TC)
Wife and I
USN MCPO (E9) Retired (active duty 1973 - 1995)
rgolding
Southern Illinois
Posted: 05/05/12 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
If nothing else, I feel certain you will at least pick up another 10 mpg by angling the nose of the trailer down as it pulled into the wind and the rear of the trailer will also act as a wind foil and help keep the tail of the trailer on the ground. Now the true advantage is when the wind is behind you and you present a larger and higher solid surface at the rear of the trailer to the wind and produce greater speed across the land minus the friction of the tires on the road. ;-)
Actually, I agree that I don't believe it will matter.
Ivylog
Blairsville, Ga. USA
Posted: 05/05/12 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
If behind a PU then lower as it needs more weight on the rear. If behind a wagon or SUV then higher as they do not need extra weight on the rear. Actually you have too much time on your hands to worry about 1/4" difference.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
Wumba
Loudon, TN
Posted: 05/05/12 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
1/4" is nothing. I would go for nose down. At least it will give you a little more rear end clearance on uneven ground.
jiveturkey692000
NE PA
Posted: 05/05/12 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
With only a 1/4 inch i would not even bother touching it again.
Dan
96 Fleetwood Mallard, 30'
05 Ford F250 Super Duty 4X4 6.0 Powerstroke, CC, Lariat 8ft Bed "Redneck Cadillac"
82 Dodge Ram W350 4X4 Clubcab. 216,000 miles
Ron Gratz
full time RVer
Are you changing the weight distribution bar loading to achieve the 1/4" up and 1/4" down?
If so, you should forget about the height of the hitch and focus on the loading of the TV's front axle.
The WDH setting which returns the front height/load the closer to the unhitched value will be the correct setting.
Ron
Chuck&Gail
In the Colorado Mountains
Posted: 05/05/12 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
TT tongue slightly LOW is best IMHO/
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
christopherglenn
a little over an hour from Yosemite
Posted: 05/05/12 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
I would go 1/4" low, that gives slightly more clearence at the rear of the trailer, think gas station driveway.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
timc1207
Posted: 05/05/12 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I think you're over thinking it.
2008 Forest River Wildwood Le 27BHBS - 2010 Dodge 2500 Laramie Mega cab 6.7L Cummins diesel, Flo-Pro exhaust, XRT Pro tuner, Mygig Lock Pick, Access tonneau cover, Ranch Hand grill guard, KC daylighters.
