RV.Net Open Roads Forum: Class A Motorhomes: Brakes on 98-2001 28-30 ft. A's
 > Brakes on 98-2001 28-30 ft. A's
sunlight
Durham,N.C.
Posted: 05/05/12 02:43pm Link  |  Print  |  Notify Moderator
The last 30' A I bought was a 92. That was the hardest brake to push. I later bought anther 30' of about the same year. It was 40% easier but still alot of effort. I have some cartilage knee issues. I noted that the 28'-- and bigger actually had 4 wheel disc brakes. What I wanted to know was was there any improvement around the 98-2001 models in the way they brake. Basically am looking at the Winn's and Itasca's. That is why I had dropped down and gotten the little Toyota motorhome. Doug
pkunk
Questa, NM
Posted: 05/05/12 05:27pm Link  |  Print  |  Notify Moderator
I need less pedal pressure in my (see sig) MH than my Mercedes ML.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
bsinmich
Holland, MI
Posted: 05/05/12 07:34pm Link  |  Print  |  Notify Moderator
It sounds like you needed a new power brake booster in a couple of old units. Boosters age also and need occasional replacement. My MH is no harder to push the brakes than my Saturn.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Weathertodd221
FL
Posted: 05/05/12 09:11pm Link  |  Print  |  Notify Moderator
keep in mind the motorhomes have a special hydraulic brake booster. Fresh fluid makes a huge difference.
