RV.Net Open Roads Forum: Travel Trailers: Insulation question
 > Insulation question
shasta24
home
Posted: 05/05/12 04:27pm Link  |  Print  |  Notify Moderator
Hope I do this right. Im new to the forum. I am rebuilding a 24 foot shasta from the frame up. All my walls are done and now Im working on the floor . Im not sure what way togo for insulating the floor. Im using two by four framing. Ill have 1.5 inches in width to fill,not much. I used corragated underbelly on top of frame then wood framing. Thanks.
donn0128
Pronounced Ore-gun
Posted: 05/05/12 04:33pm Link  |  Print  |  Notify Moderator
Personally I would hire a contractor to spray foam insulation.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
spike99
North America
Posted: 05/05/12 04:52pm Link  |  Print  |  Notify Moderator
Option 1 (which is expensive), hire a Spray Foam Contractor. Use 2 lbs (medium density) Close Cell.
Option 2 (which is less expensive), buy those DIY Spray foam tanks. I hear Tiger makes a good DIY system. Use 2 lbs (medium density) Closed Cell. For good video, surf - Click Here -
Option 3, use "poor man's spray foam" method. re: Buy some foam sheets, cut them on a table saw and use hand held spray foam cans to "lock in" their outer edges. Surf: - Click Here -
If square "consistant" areas to insulate, I'd use Option 3. But if I plan to keep the trailer for life, I'd go with option 1. Contractor Spray foam "lock in" all materials it sticks to.
Hope this helps...
downtheroad
Pacific Northwest
Posted: 05/05/12 05:00pm Link  |  Print  |  Notify Moderator
Whatever method you decide on make sure that if you have plumbing and electrical under the floor that you can still get to it easily for repairs.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
CavemanCharlie
Storden,MN
Posted: 05/05/12 05:26pm Link  |  Print  |  Notify Moderator
Take pictures of your rebuild and post them here. We love to see pictures of trailers and people rebuilding there trailers.
U.P. BLDR
Upper Peninsula of Michigan
Posted: 05/05/12 05:32pm Link  |  Print  |  Notify Moderator
I used 1" rigid foil faced foam to do mine, cut nice and tight. Used it for the walls too. It's R 7.7 for the 1". There might be pics in the link in my sig. I can tell you that my TT heats stupid easy and it didn't break the budget. The spray foam would be the ticket, but I couldn't justify the cost for my rig.
I will say that it sure took time to do all the cutting, and it got old real quick.
Found some pics.
and the walls
1981 Sunline 17 1/2SB - under construction
2003 Toyota Tundra SR5 TRD 4x4 4.7lt
shasta24
home
Posted: 05/06/12 05:59am Link  |  Print  |  Notify Moderator
Thanks for the help. I went to Lowes last night and they have 1.5 inch foam boards.THat looks to be my answer so far. As far as any plumbing issues,or electrical,my camper has all that stuff under the underbelly. I would love to share all the pictures with everyone,but I am a little slow on how to get it on here.
WyoTraveler
Northwest, Wyoming
Posted: 05/06/12 07:13am Link  |  Print  |  Notify Moderator
I used the foam board when I built a TC. I have seem some RV construction on the forum. When I built my TC I built it like the commercial companies build their RVs. From the inside out. Instead of like a stick house where you build from the outside in. Building all the walls and floor separate, then attatching them together and putting the insulation in from the outside and aluminum over the insulation. That way you can remove the aluminum panels and have complete access to all plumbing and electrical after the RV is built.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
