RV.Net Open Roads Forum: Tech Issues: Suburban SF30F furnace would not light
 > Suburban SF30F furnace would not light
arizonakid
Stow Mass. USA
Posted: 05/05/12 04:52pm Link  |  Print  |  Notify Moderator
Just a note that may help others .... everything worked, the ignitor was 1/8" from the burner (correct), but the spark was not audible and it would not light... I noticed that the the spark was very thin and weak...
I have noticed a lot of comments saying that the ignitor may be too far from the burner, but I found it may not be far enough away !
I had the furnace on the bench, hooked to a car battery, with the gas tube off so I could see the spark on the burner....
I moved the ignitor wire further away from the burner - maybe to 3/16 - and the spark was stronger and brighter. Now it lights the propane.
My theory is this: if the ignitor is close to the burner, it takes lower voltage to jump the gap, resulting in a weak spark.
Move it further away, and it requires the coil voltage to grow to a higher value before it jumps to the burner, giving a bigger, hotter spark which lights the propane.
Anyway, that's how I fixed my furnace.....
So if your gas valve opens but it does not light, check your spark...
Ka Ron
Kelowna
Posted: 05/05/12 06:03pm Link  |  Print  |  Notify Moderator
The gap distance has to do with air/gas mixture.
It requires just the right combination to ignite. If the spark is too close the air/gas mix is not right for ignition.
Join Us For A Trip Down The RV Highway
arizonakid
Stow Mass. USA
Posted: 05/05/12 07:33pm Link  |  Print  |  Notify Moderator
Well this opens a whole new concept...
I had seemingly adjusted the spark force for ignition ...
but how does one adjust the air/gas mixture ?
edit: I think I get it... too close to the burner the mix is heavy on propane, a bit further away it has a chance to mix with air.
* This post was edited 05/07/12 02:33pm by arizonakid *
nbounder
Arizona mountains
Posted: 05/07/12 07:48pm Link  |  Print  |  Notify Moderator
I had a similar prob with a Suburban furnace. The nice technician from Fleetwood said the weak spark was due to a dying circuit board. He handed me a new board and left (this was at a FMA rallye, where Fleetwood offers repair service). Anyhow, I installed the board, and it worked right off the bat. Sharp dudes, these Fleetwood guys!!
Nbounder
KG7DKF
