bayoubelle
Amite, LA
Do you leave your aerator pump operating when away for a few months?
2008 31RK Cardinal LE
2011 3500 HD Silverado LTZ
bukhrn
Lanexa, Va
Aerator Pump?
2007 Forester 2941DS
2005 KIA Spectra
dan-nickie
Grand Prairie, TX
bukhrn wrote: Aerator Pump?
Beat me to it
Dan and Nickie, Four Winds 31p, Retired Jan/2011
Old-Biscuit
Across the USA
Really depends on your system. Best to call the MFG. for recommendation.
Usually if the aerator is off for more that a few days, the system will turn septic and the aerobic bacteria will die. Over time the diffuser will become clogged.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
eHoefler
ozark mountains
Old-Biscuit wrote: Really depends on your system. Best to call the MFG. for recommendation.
What he said.
You need to leave it operating no matter which type of system you have. If a stirring type, it could sludge up, the pump or blower type can have the bacteria die off and the the support bed becomes clogged before the bacteria re-establishes. It is cheaper to leave it running than to have the system fail and have to have it cleaned and/or replaced.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
bayoubelle
Amite, LA
eHoefler wrote: Old-Biscuit wrote: Really depends on your system. Best to call the MFG. for recommendation.
What he said.
Thanks for the responses.
Wasn't concerned about the cost but wondered if it would hurt the pump if no water was being put into the tank and therefore making it harder for the pump to work?
pinesman
virginia
Must be a LA thing. Never heard of it in Virginia
Old-Biscuit
Across the USA
bayoubelle wrote: eHoefler wrote: Old-Biscuit wrote: Really depends on your system. Best to call the MFG. for recommendation.
What he said.
It pumps air into bottom of chamber....there will be water in that chamber as it will only drain down to the bottom of effluent out.
bayoubelle
Amite, LA
Good to know, thanks!
