RV.Net Open Roads Forum: Checking engine coolant level - Cummins ISB 300 HP
 > Checking engine coolant level - Cummins ISB 300 HP
2inAlabama
Huntsville, AL
Posted: 05/05/12 07:31pm Link  |  Print  |  Notify Moderator
Trying to check the coolant level in my engine, but there are no markings on the coolant reservoir. The visible coolant level is about an inch below the top of the reservoir. Should the reservoir be full?
Just DH & DW
fcooper
Richmond Hill, Georgia
Posted: 05/05/12 08:26pm Link  |  Print  |  Notify Moderator
My reply assumes that the coolant recovery tank is the same for Cat or Cummins engines since Freightliner installs the radiator. It also assumes that you have a rear radiator.
My rear radiator Freightliner does not have easy to see markings on the coolant tank, but they are molded into the white plastic. I'll admit that they are easier to see on the new tank that I just installed, but were not impossible to see on the old one. Look just below the mid line of the tank toward the right side.
From my poor memory, about one inch below the top of the tank would be within the min and max range.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
2inAlabama
Huntsville, AL
Posted: 05/05/12 08:38pm Link  |  Print  |  Notify Moderator
Thanks Fred - I'll try that.
OTTO
Western Washington/Gold Canyon, AZ
Posted: 05/05/12 08:45pm Link  |  Print  |  Notify Moderator
There is a Min. and a Max. line embossed on the poly tank. I believe my max mark leaves at least a 1" empty area on top.
sdbounderdiesel
San Diego
Posted: 05/05/12 08:59pm Link  |  Print  |  Notify Moderator
I've got my MH parked outside the house for a washing in the morning. Just checked my ISB 325 and it has Cold Min and Max lines embossed on the Clear Poly Tank on the top of the radiator. Located just to the right of the metal radiator cap. Hopefully, yours is the same.
