dbro60
Nebraska
Wondering if the angle makes a difference? RV is a Newmar Ventana. Angle is not level. My old toad was not level either but this is higher?
Dave Brown
Looking to Live the Dream
imgoin4it
Alamogordo, NM USA
Level is best for lots of reasons, but as a minimum check with the manufacturer of your tow bar for their specific specs. I know that some tow bar manufacturers will void any warranty for any damage to the bar or base plates if you are out of spec.
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
cm
Dillon, CO USA
Level plus or minus 2" is the standard per their web site.
dashdriver
Colorado
Readybrute specifies +/- 2 inches in their manual. You can use drop/rise hitches to help level things out. Not sure what the exact specs on your truck are but most 3/4 ton pickups are over 6500 lbs bone dry. You'll need to be careful not to overload the pickup beyond what the towbar is capable of (Readybrute is 8000 lbs).
1999 HR Navigator 42DSS
2008 Jeep Wrangler Unlimited (4Dr)
dbro60
Nebraska
dashdriver wrote: Readybrute specifies +/- 2 inches in their manual. You can use drop/rise hitches to help level things out. Not sure what the exact specs on your truck are but most 3/4 ton pickups are over 6500 lbs bone dry. You'll need to be careful not to overload the pickup beyond what the towbar is capable of (Readybrute is 8000 lbs). I am 10" above the receiver on my units. I have a Blue Ox baseplate. I am going to call Readybrutetomorrow and see if they have a baseplate that will go below the bumper instead of through it. That would put me where I need to be. If they don't, I'll put my Audi Q7 on a trailer and pull that until I figure this out.
LoneCowboy
Colorado
dbro60 wrote: dashdriver wrote: Readybrute specifies +/- 2 inches in their manual. You can use drop/rise hitches to help level things out. Not sure what the exact specs on your truck are but most 3/4 ton pickups are over 6500 lbs bone dry. You'll need to be careful not to overload the pickup beyond what the towbar is capable of (Readybrute is 8000 lbs). I am 10" above the receiver on my units. .
get a drop hitch and use it backwards (upside down)(the drop goes up)
they make drops every 2". although ti's tough to get one rated for over 5000lbs, but they do exist.
dashdriver
Colorado
Wow...yeah 10" is a lot, especially with the toad being higher. etrailer.com has some that will fit your needs.
bluwtr49
Green Valley, AZ
Have you ever considered just picking up an inexpenxive vehicle just for use as a toad and beating around???
Something like an old(er) Jeep GC, Cherokee, Wrangler and etc tow great, are easy to hook up. We did that and were ready to tow for less than 5K including wiring and tow base plate.
Just a thought.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
