silvercorvette
Anderson SC
Skip down to this post (Posted: 05/06/12 01:18am) the rest are messed up
I bought some ice cream salt yesterday, and boy does salt taste terrible on ice cream.
I am having problems posting and am trying to break it down into small parts maybe that will work
last
edited 05/05/12 11:21pm by silvercorvette *
View edit history
2010 Dodge 409 CI diesel long bed dually crew cab B&W hitch, 95 Gallon Auxiliary Transfer Fuel Tank, pulling a 33 foot Holiday Rambler Alumascape suite, Winegard SK-3005 TRAV'LER , Central vac, Splendide 2100 XC washer dryer, Rotochoks, TST Tire monitor.
BobsYourUncle
Surrey, BC Canada
Somehow, putting salt on my ice cream has never occurred to me.........
Duramax / Allison
Fire Red
1997 Triple E Topaz 27' Bunkhouse TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
silvercorvette
Anderson SC
I don't know what is wrong, I copied this to a word program and am trying to paste a small part at a time, I may have to retype the whole thing
BobsYourUncle
Surrey, BC Canada
Site sometimes has issues.
I just had a problem posting a response to another thread.
Try going to http://forums.woodalls.com/ log in with same credentials and try posting from there.
I just did and it works. Sometimes the site can be a bit quirky for some reason. I could post a response in one thread but not another.
silvercorvette
Anderson SC
I am trying to post a thread about buying a crank operated machine that uses crushed ice and you use salt to make the ice colder
silvercorvette
Anderson SC
OK just kidding, For the past few years I have been using a Kitchen Aid ice cream maker and was not 100% happy with it. It took up a lot of freezer space and if you stored it outside the freezer you had to put in it the freezer a least a day and a half ahead of time. Also I noticed that when I visited friends their freezers did not get the container cold enough. I keep my freezer set to max cold and I consider the results to be adequate.
I have seen a few hand crank models for ale but the cheapest hand crank non electric was more than I wanted to spend.
So the other day when I was in Sam's club I saw one selling for $55 I grabbed it up, the ON LINE PRICE IS $77 plus shipping. There were a few reviews with complaints about the motor but Sam's has always been good with returns and I paid an extra $7 for a one year replacement warrantee so I am not worried..
And the thing I like about this machine is that it has both an electric motor and hand crank which will eliminate the need for electricity while camping. All you need to do is bring some ice or buy a bag (yes I do know you put the salt in the ice to make it colder)
My two favorite flavors are chocolate and strawberry, I am going to mix up my first batch of strawberry ice cream tomorrow and load it up with a lot of strawberries. When I don't make my own I usually buy the expensive stuff in the store but none of the most expensive store bought stuff compares to home made. If you don't own an ice cream maker and are a Sam's member I suggest you try one out I have never seen one this cheap. Only time will tell how well the motor holds up but you have the hand crank as a back up and for 7 buck extra you have a one year return replacement.
silvercorvette
Anderson SC
Thanks bobsyouruncle it worked
BobsYourUncle
Surrey, BC Canada
silvercorvette wrote: Thanks bobsyouruncle it worked
Good, I learned a long time ago that occasionally the site has issues and when it does, I temporarily go to another portal and post from there.
Works almost every time. I find that when RV.Net burps, Woodalls usually works.
silvercorvette
Anderson SC
By the way I bought salt to use in the machine and this is exactly what was written on the box
"ICE CREAM SALT" I thought the wording was odd.
silvercorvette
Anderson SC
BobsYourUncle wrote: silvercorvette wrote: Thanks bobsyouruncle it worked
I am a poor typist and type slowly, so on a long post I make it a habit to copy and paste to a word doc so if it messes up I can just copy , paste and repost, I made countless attempts even breaking it down to smaller parts and my attempts also included re-booting and I would still be messed up if it wasn't for your suggestion.
I'll keep that in mind for future refference
