RV.Net Open Roads Forum: Tow Vehicles: Duramax oil drain plug drama
Search only in Tow Vehicles
 > Duramax oil drain plug drama
Page of 6
2006blackmax
Posted: 05/06/12 05:25am Link  |  Quote  |  Print  |  Notify Moderator
I always do my own oil changes ,all info online states 62 ft lbs for torque.. I have used a torque wrench every oil change.Yesterday my drain plug was stripped and would not tighten..My truck is at Chevrolet getting the oil pan replaced. I highly recomend not going 62 on yours. I hope this saves. Someone some trouble.
* This post was edited 05/07/12 05:08pm by 2006blackmax *
2006 2500HD Duramax LLY with Allison 6 Speed W /Mods
2008 Jayco Eagle Super Lite 27.5RKS
eye8Ubutler
Maritime Provinces
Posted: 05/06/12 05:36am Link  |  Quote  |  Print  |  Notify Moderator
2006blackmax wrote:
I always do my own oil changes ,all info online states 62 ft lbs for torque.. I have used a torque wrench every oil change.Yesterday my drain plug was stripped and would not tighten..My truck is at Chevrolet getting the oil pan replaced. I highly reccomend not going 62 on yours. I hope this saves. Someone some trouble.
I sympathise...I have never owned/used a torque wrench...I think I am worried about doing what ya did!
Chevrolet Silverado 1500 LTZ 2007 (new shape)
4x4 Crew Cab VORTEC MAX (L76) 6.0L V8 4L70E 4.10 axle
factory NHT Max Trailering Package.
2010 Coachmen Freedom Express 280 RLS
"...a Waldorf Salad?, sorry we are fresh out of Waldorfs!".......BASIL FAWLTY.
Tarantula
Saint John, IN
Posted: 05/06/12 05:37am Link  |  Quote  |  Print  |  Notify Moderator
I don't know if you're using a 'clicker or dial' type torque wrench. If it's a clicker, do you turn the setting back to zero after each use. Not doing so will, in time, give you false readings.
Our Unit: 2011 Lexus ES. Matador red. . Previously '05 Dodge/CTD & '06 Montana 3000RK.
gmcsmoke
Butler
Posted: 05/06/12 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Fumoto valve ftw.
tkcrawford
Edmonton, Alberta
Posted: 05/06/12 07:47am Link  |  Quote  |  Print  |  Notify Moderator
gmcsmoke wrote:
Fumoto valve ftw.
X2. Very good investment.
2004 Dodge Laramie 3500 Dually, CTD 305/555, Quad Cab, 4x4, NV5600
2008 Eagle Cap 995
xaugievike
Chicagoland
Posted: 05/06/12 07:48am Link  |  Quote  |  Print  |  Notify Moderator
tkcrawford wrote:
gmcsmoke wrote:
Fumoto valve ftw.
x3
2006 Chevy Silverado 2500hd D/A LBZ
Pulling Keystone Cougar 325SRX
chiefneon
Livingston, TX
Posted: 05/06/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Howdy!
X2 on the Fumoto Valve. I've had one on our C5500 Chevorlet Kodiak form the first oil change. Never been a problem and makes for easy oil changes.
http://www.fumotousa.com/
"Happy Trails"
chiefneon
WyoTraveler
Northwest, Wyoming
Posted: 05/06/12 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I own torque wrenches but never used them on an oil drain plug.
I suspect the easiest fix would be to drill out the bolt hole and re-tap for a larger drain plug.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
RAS43
Littleton,CO
Posted: 05/06/12 10:32am Link  |  Quote  |  Print  |  Notify Moderator
62 ft lbs seems like a lot for a drain plug, maybe in an aluminum pan that has some thickness. I never have used a torque wrench for that anyway. But my career was as a mechanic so I developed the "feel" of how tight the plug should be. Never lost one either.
45Ricochet
North Idaho
Posted: 05/06/12 10:38am Link  |  Quote  |  Print  |  Notify Moderator
xaugievike wrote:
tkcrawford wrote:
gmcsmoke wrote:
Fumoto valve ftw.
x3
X4. The Cummins is known for stripping also. Plus getting a sample between changes is a breeze.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Page of 6
