CND SuperCrew
SK, Canada
Another vote for a Fumoto valve...
Ron, Lori and Autumn
TV 2012 F150 loaded XLT EB SuperCrew 7700GVWR Maxtow 6.5'
TT 2008 Jayflight G2 23FB/ Equal-i-zer WD
2013 Colorado bound
2012- 4000km, 28 nights for the season
2011- OR & CA done, 6800km in 3 weeks
2006blackmax
smkettner wrote: Clear head should prevail that 62 is way too much for a drain plug.
You would need a grade 5 nut on the other side for that torque.
LOL.....Smart Guy Huh?
2006 2500HD Duramax LLY with Allison 6 Speed W /Mods
2008 Jayco Eagle Super Lite 27.5RKS
#1Flyboy
California
. . .Fumoto on mine; mechanic loves it. . .
2006blackmax
Might check into those,I heard a little slow draining though. Is that the case ?
Thanks....
RollingRockTX
Keller, Texas
2006blackmax wrote: Might check into those,I heard a little slow draining though. Is that the case ?
Thanks....
maybe like 3 extra long min.
2006 Ford F250 King Ranch PSD
ARP Headstuds
ERG Delete
Diesel Site Coolant Filter System
Gearhead Performance Tuned, via XCALII, Edge Insight CTS
MBRP 4" Turbo Back, cat delete
MagHytech Rear Dif Cover
2011 Ford Expedition, HD Tow
2011 Cruiser CF33LF, KC5PFG
sniperduce
Norman, Oklahoma
I have a fumoto on very vehicle. In my ford I drain the 14.5 qts into 3-5 qt jugs with a short hose. No mess and no drain pans.
"Sniperduce"
2004 F350 PSD 6.0L 4x4 FX4 Lariat Crew Cab SB SRW Linex, etc.
2011 Montana Mountaineer 347 THT
16K Reese Slider Prodigy BC
2008 Harley Davidson Ultra Classic
summithmk
butt#$%$ egypt, NV
ib516 wrote: Maybe it's supposed to be 62 inch pounds?
Troll.
bucky
Eastern Shore of MD
ib1516 has been a long time member here, I would not count him as a troll.
99 K3500 DUALLY 07 JAYCO 345 BHS
Ron3rd
Upland, CA USA
Thanks....
Yes, they do drain slower but what's the rush? I'm sold on the Fumoto like the others. My Tundra holds just under 8 qts. I open the Fumoto, take a break and come back in 15-20 minutes. Gave up on drain plugs years ago and use Fumotos on all my vehicles.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
RCMAN46
NorthWest
Thanks....
I have the Fumoto Valve on my DMAX. Yes slower drain than with drain plug. But if oil is warm (which it should be) mine has drained by the time I have greased the front end and removed and replaced the oil filter. Thus it does not add any time to the overall procedure in changing the oil.
