2006blackmax
Thanks Everybody, Gonna look more in the Fumoto Valve, I really like the idea of teathering handle..........Thanks Again
2006 2500HD Duramax LLY with Allison 6 Speed W /Mods
2008 Jayco Eagle Super Lite 27.5RKS
LowRyter
OKC
RCMAN46 wrote: 2006blackmax wrote: Might check into those,I heard a little slow draining though. Is that the case ?
Thanks....
I have the Fumoto Valve on my DMAX. Yes slower drain than with drain plug. But if oil is warm (which it should be) mine has drained by the time I have greased the front end and removed and replaced the oil filter. Thus it does not add any time to the overall procedure in changing the oil.
where are the zerks? maybe a dumb question but I don't know what needs the be greased.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
LowRyter
OKC
WyoTraveler wrote: I suspect the easiest fix would be to drill out the bolt hole and re-tap for a larger drain plug.
+1
msjdbman
SW Michigan
Hey fellas....it took me all of 3 minutes to look up the recommended torque spec for the DMax oil pan drain plug, and it is indeed 62 lb ft. I had been reading this thread thinking, heck, the torque on old chevy small block rods was around 45-50 lb ft...and those were just 3/8 inch rod bolts.
2008 Duramax/Allison LT2 Crew cab Standard Box. Hellwig Air Assist. BD Diesel VVT Turbo Brake. 2003 Coachmen Chaparral 295 IKS
KD4UPL
Swoope, VA
LowRyter wrote: RCMAN46 wrote: 2006blackmax wrote: Might check into those,I heard a little slow draining though. Is that the case ?
Thanks....
Upper and lower ball joints have zerks. Each tie rod end has one. Also, where the tie rods join the steering rod (maybe it has a better name).
The pitman arm and idler arm also have zerks. They face up toward the engine and are hard to see and hard to get too. That's all I have found on any of my Chevy trucks.
Do you not grease yours? That sounds like a front end ready to be replaced.
LowRyter
OKC
KD4UPL wrote: LowRyter wrote: RCMAN46 wrote: 2006blackmax wrote: Might check into those,I heard a little slow draining though. Is that the case ?
Thanks....
I've only had min for 10k miles (40K on the truck itself). I've had it serviced for oil changed twice. I asked the servicer to lube it.
But I want to be sure. I wonder if it's in the owner's manual?
45Ricochet
North Idaho
Quote: I've only had min for 10k miles (40K on the truck itself). I've had it serviced for oil changed twice. I asked the servicer to lube it.
You still trust that thing
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
BenK
SF BayArea
Typical GM full sized has 11, with some having 12
Do a search....I've posted pictures...
-Ben Picture of my rig
BenK
SF BayArea
http://www.rv.net/forum/index.cfm/fusea........d/15463207/gotomsg/15463330.cfm#15463330
BenK
SF BayArea
Okay, at the office and not on the smartphone...the last two were
messed up with fat finger typo's...
Here are better links, but their embedded links to some of my
old forums are no longer valid
How often do you change the oil?
How many grease fittings in 04 GMC 2WD front end
4 ball joints
4 tie-rod ends
2 idler arm
1 pitman arm
1 front drive-shaft <<<<< this one is the 12th only on 4x4's
I have the images for each, but am in the middle of switching over to a new
workstation and slow going getting the other two computers and laptop sync'd...
