RAS43 wrote: 62 ft lbs seems like a lot for a drain plug, maybe in an aluminum pan that has some thickness. I never have used a torque wrench for that anyway. But my career was as a mechanic so I developed the "feel" of how tight the plug should be. Never lost one either.
Ditto...seems way too much for a drain plug and more like a small
car's lug nut torque, IMHO
What does the shop manual (not glove box manual) say?
-Ben Picture of my rig
I use a 12" ratchet, tighten it till it stops, then hit the end of the ratchet with my hand till it moves about a quarter to half an inch. Never had a leak, or anything else.
Thanks Guys, Oil Pan is getting replaced, all shop manuals, Duramax sites,Amsoil site say 62 ....I say different after this lil escapade....I even use anti seize on all my plugs.....way too much TQ ......don't care what they say.
CAPACITIES:
Engine, with filter..........10.1 quarts [1]
Cooling System, With AT Initial Fill..........25.4 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, With MT Initial Fill..........25 quarts
Automatic Transmission, 1000 Initial Fill..........7.4 quarts [2]
Automatic Transmission, 4L80-E Initial Fill..........7.8 quarts
Automatic Transmission, Total Fill
6 speed 1000..........12.7 quarts
4 speed 4L80-E..........13.6 quarts
Manual Transmission, S6-650 (6-SPD)..........12.7 pints
Differential, With 8.25 RingGear Front..........3 pints
Differential, With 9.25 RingGear Front..........3.6 pints
Differential, With 10.50 RingGear Rear..........5.5 pints
Differential, With 11.50 RingGear Rear..........6.4 pints
Differential, With 8.6 RingGear Rear..........4.3 pints
Differential, With 9.50 RingGear Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........6 pints
Transfer Case, NVG 149-NP3..........4.5 pints
Transfer Case, NVG 246-NP8..........4.1 pints
Transfer Case, NVG 261-NP2..........4.1 pints
Transfer Case, NVG 263-NP1..........4.1 pints
[1] After refill check oil level.
[2] DO NOT drain the fluid if only the transmission spin-on oil
filter is being replaced.
TORQUES:
Oil Drain Plug.....62 ft/lbs
Manual Transmission NV4500
Fill Plug 27 ft/lbs
Drain Plug 27 ft/lbs
Manual Transmission ZF S6-650
Fill Plug 26 ft/lbs
Drain Plug 26 ft/lbs
Transfer Case NVG263-NP1
Fill Plug 15 ft/lbs
Drain Plug 15 ft/lbs
Transfer Case NVG261-NP2
Fill Plug 15 ft/lbs
Transfer Case NVG246-NP8
Fill Plug 15 ft/lbs
Transfer Case NVG149-NP3
Fill Plug 15 ft/lbs
edited 05/06/12 06:20pm by 2006blackmax *
2006 2500HD Duramax LLY with Allison 6 Speed W /Mods
2008 Jayco Eagle Super Lite 27.5RKS
Specs found here say 18 ft lbs for oil drain plug. I can't imagine any need to crank 62 lbs on a drain plug!
On edit, The list I linked to are for 2011-2012 trucks. I see the torque specs under the 06-07 trucks on that site do show 62 lbs, but I suspect it must be a misprint. Maybe it should have been 26 lbs?
edited 05/06/12 02:38pm by RedG *
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
All of the other drain plug specs say 26 or 27. I'm betting it's a misprint in the manual. Maybe GM owes you an oil pan.
I'm glad I never bother to break out the torque wrench for that bolt. I don't want to get it dirty. I just make it tight. It's been fine for 7 years so far.
