Bob6907
NJ
Hello, I have a 2012 GMC Denali 2500HD Crew Cab 6.5 bed 6.6 Duramax my manual says it has a 14,700 fifth wheel towing limit with a 2500lb. pin weight. I have to questions i'm looking at a 37ft Jayco with a 12,385 Dry weight and a 2800lb. pin weight do you think it will tow ok? Second question do'es anyone no why the same exact truck in a Chevy Silverado has 15,800 fiith wheel towing limit?
Thanks
Bob
edited 05/06/12 07:55am by Bob6907 *
gmcsmoke
Butler
If its a 2500hd it's too much trailer if a 3500srw then you're good to go.
penney75
calgary alberta
I believe that will be pushing it with the Denali. The reason why the Silverado has a higher tow rating is because it has slightly stiffer springs because the Denali rides a little softer. I Also suspect the Silverado has less creature comforts then the Denali has and therefore weighs a little less.
2007 chev 2500HD Duramax crewcab 4x4, 2011 eagle superlite 305bhlt
Bob6907
NJ
Thanks it is 2500HD Denali with alll the buttons but the Chevy 2500HD was a LTZ with all the buttons it just seems strange that its 1100lb differance.
Bob
Bob6907
NJ
The dealer keeps trying to sell this Jayco to me I thought it was to much trailer for my truck
penney75
calgary alberta
What model Jayco is it?
Bob6907
NJ
It's a Jayco 2009 Designer with 2 A/C and 4 slides
penney75
calgary alberta
You may want to ask the local GMC dealer why it has a lower limit. Either truck though I think you would be at your max or slightly over. Just my opinion.
Snow_King
Gold Canyon, AZ
Bob6907 wrote: Hello, I have a 2012 GMC Denali 2500HD Crew Cab 6.5 bed 6.6 Duramax my manual says it has a 14,700 fifth wheel towing limit with a 2500lb. pin weight. I have to questions i'm looking at a 37ft Jayco with a 12,385 Dry weight and a 2800lb. pin weight do you think it will tow ok? Second question do'es anyone no why the same exact truck in a Chevy Silverado has 15,800 fiith wheel towing limit?
Thanks
Bob
Did you not answer your own question.
towing limit with a 2500lb. pin weight -
And that pin weight will go higher as you load the trailer.
What does the rear axle of your truck weight with the hitch installed?
What is the Rear GAWR?
Somewhere in a Fifth Wheel - Where it does not Snow
RedG
Fort Worth Texas
You can tow it, but you'll be overweight and are not going to like it.
I bought an 08 Jayco Designer and had a 2005 Chevy Duramax 2500 crew cab short bed and found out quickly that that big of a trailer with a 3/4 ton short bed truck is not a good combination.
The Designer will push you all over the road and you will be on the edge of your seat the whole time you're towing.
Didn't take me long to upgrade to a 3500 dually and it turned white knuckle driving to a relaxed comfortable ride.
Don't know about your weight comparison with the Chevy, but maybe it's 2wd and you're 4wd?
I really love my Jayco Designer, but speaking from experience, I wouldn't recommend towing one with a 2500. Too much pin weight.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
