RV.Net Open Roads Forum: Tow Vehicles: GMC Denali towing limit
Search only in Tow Vehicles
 > GMC Denali towing limit
SDM
KANSAS CITY MO.
Posted: 05/06/12 03:28pm Link  |  Print  |  Notify Moderator
You can pull the trailer but the pin weight may be to much.
smurf
South Dakato And Wa.
Posted: 05/06/12 03:55pm Link  |  Print  |  Notify Moderator
I have an 04 GMC 2500 Duramax HD long bed with an Allison and pull a 05, 364 Everrest 5th wheel with 4 slides ,with a 50gal. ax tank in the bed I gross 22,000# front axel over loaded by 200# till I use some fuiel.
We have been in every state west of the Mississipp never lacked for power. I have 125,000 miles on it now.Never know it back there Wife drives also we full time!
Please just move over so i can get BUY .
2004 GMC HD 4x4 Douramax with Allison transmission loaded.
20005 36ft. Everest W/ 4 slides loaded.
Full timing and having fun
No matter where you go there you are
Papa Smurf driver
Mama Smurf Professional Passenger
JTrac
Oklahoma
Posted: 05/06/12 04:44pm Link  |  Print  |  Notify Moderator
According to the GMC website your max payload is 2545 lbs in a single rear wheel, 4wd Denali 2500HD. Fill your tank and weigh it with you in it then add the weight of the hitch, your spouse, dogs, tool box with tools or whatever you will travel with and see what is left. You might be surprised how quickly you lose your payload capacity before you even hook up to a fifth wheel.
I just got my new 3500 Denali last month. I weighed it last week with the things I have added since I bought it: new B&W Comapanion hitch, spray bed liner, running boards, and full liner floor mats. I also filled the tank and sat in it while it was weighed. I lost 585 lbs off my stated capacity. By the way, you have a 6200 lb rear gross axle weight rating.
JimT
2013 Excel Winslow 34RKM pulled by a 2012 GMC 3500 Denali diesel, faithfully assisted by my wife and the two Bostons
sirdrakejr
Las Vegas, Nevada
Posted: 05/06/12 08:58pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to tow vehicles.
Frank
Pete_k
Stantonville Tn
Posted: 05/07/12 04:53am Link  |  Print  |  Notify Moderator
Smurf this just shows, most can't drive. They jump into a pickup and camper. They have never driven anything bigger then there personal auto. I see it on here all the time. Man that drive is killer Or what they love to call (WHITE KNUCKLE DRIVE)Now if they had ever had the pleasure of driving a big truck loaded to the max or more. They then would see, every size and shape of rolling hauling towing truck does not drive the same as there Town Car does. Its a truck its going to make you drive not kick back and relax and take your eyes and mind off what your doing..
Still think fed's needs to set up a test for all campers. I had to show I could handle 80,000 lbs or more. But a person can jump into the same size truck/camper and then take off.
Days of a Tri-Axle dump truck 74,000 lbs sitting on the back just like our pickup's. You don't drive it, you keep it between the lines. Its not a relaxed drive.. 80,000 lbs or more on a tractor and Trailer is not kicked back and relax. But not bad to anyone that does it. But we load a pickup down to its max load limits and were death on the roads waiting to kill the world.
Thanks Smurf for being one that knows there truck can handle it. Plus know how to drive it.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
smurf
Posted: 05/07/12 08:05am Link  |  Print  |  Notify Moderator
Like it Peter K well sayed !!!! I have been on for 9 years and have read
the weight police and just shake my head.
Just move over guys or park it.
dubdub07
Colorado Springs
Posted: 05/07/12 09:40am Link  |  Print  |  Notify Moderator
I have got to jump on this bandwagon! I agree! I am at 36ft, four slides 13K camp ready and a hitch wt of around 2500lbs. I would easily go 3-400 more in pin wt and not blink an eye......
Oh, yea.....I can only go one direction without hitting an 8% grade, and that's east. I agree with the smurf......if you see me coming up behind you, kindly move aside and I will smile and wave nicely as I go by.
Unless you want a dually, keep the Denali 2500 and put some bags on the back, shocks or a helper springs. No worries.
2013 Fleetwood Discovery 40G
TOADS: 2012 Jeep JK Rubicon, 2012 Durango Citadel
2010 Harley Heritage Softail....American STEEL = American profits.
Ric Flair
Posted: 05/07/12 09:43am Link  |  Print  |  Notify Moderator
Here they come!
2013 GMC 3500 DRW 4x4 SLT Duramax
2013 Road Warrior 415 Toy Hauler
2013 Kawasaki 4010 Mule
45Ricochet
North Idaho
Posted: 05/07/12 10:46am Link  |  Print  |  Notify Moderator
Pretty simple you first decide which rating you want to follow. A: The manufactures suggestion payload (2500 lbs in your case), B: the RAWR (6200 lbs in your case) or C: someone typing on the Internet.
Example A doesn't need explaining.
Example B you'll need to scale your truck loaded ready to hitch up. Subtract your scaled drive axle weight from your 6200 lb RAWR (most likely your tire rating also). That number is your max LEGAL weight in many states.
Example C forget all rating just hook up and go (which is legal in some states).
Remember nobody tows dry weight. IMO your pin will be well north of 3k.
Your DMAX will have no problems towing that weight.
Good Luck
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
