RV.Net Open Roads Forum: Class A Motorhomes: Dim brake light
 > Dim brake light
jwiz7
Arizona
Posted: 05/06/12 07:24am Link  |  Print  |  Notify Moderator
One of my brake lights works but is dim. Anyone have ideas on what the problem could be? 04 Monaco Monarch
kaydeejay
SE Michigan, USA
Posted: 05/06/12 07:28am Link  |  Print  |  Notify Moderator
If changing the bulb doesn't work, check the ground.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 05/06/12 07:29am Link  |  Print  |  Notify Moderator
Try your turn signals and see which one is dim? If it's easy to take the covers off the bulbs and look at the filaments as they work you will find the problem easier. The dim bulb is actually using the run light filament.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
rgatijnet1
Posted: 05/06/12 07:30am Link  |  Print  |  Notify Moderator
Check your ground wires on that side for corrosion. You can run a jumper wire from a good ground on the coach and touch it to the side of the brake light socket. If the bulb brightens, you then have to trace where the original ground has deteriorated.
rk911
Wheaton IL
Posted: 05/06/12 10:35am Link  |  Print  |  Notify Moderator
yup but i'd do that in reverse order. checking the ground is free and i'm che...er...thrifty.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
furycove
Vancouver Island
Posted: 05/06/12 10:43am Link  |  Print  |  Notify Moderator
If access is easy, just try swapping the brake bulbs from side to side, if the problem changes sides, it is the bulb, if it stays on the same side, it would be the socket.
Cheers,
Grant
kaydeejay
SE Michigan, USA
Posted: 05/06/12 06:42pm Link  |  Print  |  Notify Moderator
The trade off is cost vs. level of aggravation!
In my books changing the bulb is easier than tracing a bad ground.
You DO carry spares don't you?
smkettner
Posted: 05/06/12 09:19pm Link  |  Print  |  Notify Moderator
Fix the ground.
675 watts solar
jwiz7
Arizona
Posted: 05/08/12 06:16pm Link  |  Print  |  Notify Moderator
Thank you for the help i was able to fix it today. What a good site.
crasster
Dallas
Posted: 05/08/12 06:24pm Link  |  Print  |  Notify Moderator
Yes, these guys & gals are very helpful here. What did it turn out to be?
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
 > Dim brake light
