RV.Net Open Roads Forum: Water Filter & Surge Protector Needed at Topsail RV Park??
 > Water Filter & Surge Protector Needed at Topsail RV Park??
reubenray
Pearl River, LA.
Posted: 05/06/12 07:42am Link  |  Print  |  Notify Moderator
These two items are something that I have not totally decided on if I need them or not (at least for this first trip). We will be staying at the Topsail RV (State Park) in Florida.
We will most likely bring our bottled water with us and not drink their water. My main concern if water for coffee and cooking. So will I still need a filter?
I already have a 50 amp to 30 amp dogbone to make sure I get the full 30 amps of power. If I am talked into getting a surge protector will there be any issues with the dogbone and then the surge protector plugged into the dogbone?
2013 Tiffin Allegro 31SA
2010 Chevy Equinox
rr2254545
Minnesota/New Mexico
Posted: 05/06/12 08:15am Link  |  Print  |  Notify Moderator
I have used the water there many times for coffee etc. Was fine by me. You never know when you will need a surge, this is not a campground specific need.
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
JRS & B
Florida/Michigan
Posted: 05/06/12 09:32am Link  |  Print  |  Notify Moderator
We stayed at TopSail one time for a two-week period. The water seemed fine to me.
We also had no problem with power quality.
BUT, there are two camps with strong opinions regarding surge protection (Those that believe in them completely and those that don't think they are worthwhile at all. And I honestly don't know who is right.
I converted over to the camp that says they are good insurance.
Our surge protection unit tripped a number of times due to apparent voltage irregularities. I compared notes with another camper who had a fancy unit with a meter that read the actual voltage. In each instance my unit tripped from high voltage conditions.
skipnchar
Topeka or somewhere else
Posted: 05/06/12 10:42am Link  |  Print  |  Notify Moderator
If you don't need them anywhere else you won't need them anywhere. It really has little to do with the particular RV park you're in.
GoofMan
Kitchener, Ontario, Canada
Posted: 05/06/12 02:22pm Link  |  Print  |  Notify Moderator
The problem is when you find out you need a surge protector it's too late.
Carbon filters (which are mainly what people use) are for bad taste and odors, but won't do anything for bacteria. It all depends on how sensitive you guys are to funny tasting water.
If the water at the park is contaminated you'll have to boil it anyway.
2002 Dodge Ram 1500 Quad Cab
2011 Palomino S-195 SD
Rob & DW
DD (Thing 1)
DS (Thing 2)
2011 - 19 Nights Camped
2012 - Prepping for big 2 week Disney trip.
joraz
Tucson
Posted: 05/06/12 02:50pm Link  |  Print  |  Notify Moderator
Had sand in our water. Hence, the water filter. Almost fried our shiny, new $2,000 inverter. Hence, the surge protector. And I'm an optimist!
jor
95 Foretravel
Cummins M11 400
Allison 4060
M GO BLUE
Southgate, MI
Posted: 05/06/12 03:05pm Link  |  Print  |  Notify Moderator
You should not have to have a reason to get a multi-function surge protector...might also suggest the same for a water pressure regulator also
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
Allworth
Orlando, FL
Posted: 05/06/12 03:40pm Link  |  Print  |  Notify Moderator
If you feel you MIGHT need the filter or the protecter and you do not get them, then you will fret about it the whole time.
If in doubt, go ahead and get them. The peace of mind is worth every penny.
By the way we use a simple Camco in-line filter and no power conditioner. I do keep a vilt meter and citcuit tester plugged in all the time.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
reubenray
Pearl River, LA.
Posted: 05/06/12 06:05pm Link  |  Print  |  Notify Moderator
Will there be any issues with the dogbone and then the surge protector and then my power cord?
M GO BLUE
Southgate, MI
Posted: 05/07/12 05:22am Link  |  Print  |  Notify Moderator
No...none at all
