RV.Net Open Roads Forum: Where is the Air Filter on an Onan 7500 HDKAJ Diesel Gen?
 > Where is the Air Filter on an Onan 7500 HDKAJ Diesel Gen?
rufnit
Wherever We Park It
Posted: 05/06/12 08:18am Link  |  Print  |  Notify Moderator
Just spent an hour on the internet trying to find the location of the air filter with no luck. Hopefully SOMEONE here has changed it and can clue me in to it's whereabouts. The operator manual shows a nice picture of the air cleaner housing but no clue as to where to find it. Thanks in advance.
2007 Discovery 40X with 2013 Jeep Grand Cherokee TOAD
TN Camper
Valkyriebush
Yuma/Port Townsend
Posted: 05/06/12 08:21am Link  |  Print  |  Notify Moderator
It's inside the access hatch, same place as the oil filter, on the other side? You have to remove the bolts holding the canister. Easy change.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
rufnit
Wherever We Park It
Posted: 05/06/12 08:45am Link  |  Print  |  Notify Moderator
I was just in there yesterday and changed the fuel and oil filters but did not see the air filter. Will look again. Thanks.
dashdriver
Colorado
Posted: 05/06/12 09:27am Link  |  Print  |  Notify Moderator
On my 10k it is on the top left after you open the access cover. Cylindrical in shape. Mine just requires unsnapping retaining clips. After the clips are released, you just pull the air filter housing towards you and it comes off with a few wiggles.
1999 HR Navigator 42DSS
2008 Jeep Wrangler Unlimited (4Dr)
cbeierl
Nashua, NH
Posted: 05/06/12 10:18am Link  |  Print  |  Notify Moderator
If you take a look at pages 8 and 20 of the Owner's Manual you will see where it's located and how to change it. As the illustration shows, you just reach up into the opening beside the cooling air inlet grill and undo the wing nut holding the cover on the filter.
Chris Beierl
2005 Winnebago Vectra 36RD
johntichy
Posted: 05/06/12 12:57pm Link  |  Print  |  Notify Moderator
It under the front right.
gswcgi
Wandering
Posted: 05/06/12 02:41pm Link  |  Print  |  Notify Moderator
Make sure your generator is cold or you will never forget the experience!!
'03 Safari, DP, 36" Nissan 4X4 toad
Big Katuna
Deland, FL
Posted: 05/06/12 03:07pm Link  |  Print  |  Notify Moderator
Yes. ANd the screw that holds it in faces the front. It is not inside the fuel/oil filter door.
My Kharma ran over my Dogma.
Big Katuna
Deland, FL
Posted: 05/06/12 04:07pm Link  |  Print  |  Notify Moderator
YOUTUBE is a very good source for videos on just about anything. Here is one on servicing the ONAN Quiet Diesel.
CLICKY LINK
Valkyriebush
Yuma/Port Townsend
Posted: 05/08/12 08:03am Link  |  Print  |  Notify Moderator
My bad, It is not in the compartment. Got confused. Sorry.
