surgtech56
michigan
I bought a new annode rod because the old one was very oxidized, the new one has more threads. This is the first time replacing this, it seems the rod only wants to screw in so far(probably the threads?), I hate to force anything. We had it winterized and they removed the rod, so I don't know how hard or easy it was. I know I'm probably making it harder than it is, Any help please??? Thank you
We have a 2011 Gulf Stream Ameri Lite 23BW
hershey
Albuquerque,(fulltime) NM, USA
The threads are pipe threads. They are tapered unlike a bolt thread which is not. So the farther you screw the rod in, the tighter the fit.
You indicated that the new rod has more threads so with that: you won't be able to screw it in to the same point as the old rod.
As long as you get two or three turns on the connection and it doesn't leak, your good to go.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
Fishinghat
Western Washington, USA
hershey wrote: The threads are pipe threads. They are tapered unlike a bolt thread which is not. So the farther you screw the rod in, the tighter the fit.
Good advice. Couldn't have said it better.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
surgtech56
michigan
Thank you so much. It looks like it wants to go in almost 4 threads. I put some white plumbers tape on.
Jonesz
Minnedosa
Your unit is a 2011 so the rod should not need replacing. Oxidation means nothing- the rod is sacrificial in that it is designed to erode due to chemicals & minerals in the water protecting the water heater liner. My unit is an 03 and the rod is still servicable. So unless you have been in contact with some very extreme water conditions replace the old one or keep it as a spare in the eventuality that your replacement wears out. My 2 cents worth.
Jonesz
Johnworth914
USA!
I just bought an 03 Pleasureway. One of the first things I went to do was clean out the water heater. I was horrified to see that there was absolutely no annode rod attached to the plug. It must have entirely eroded.
I quickly put a new one on, but I hope I was not too late!
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
retired1
arizona
Depends on where you live and the water that you have to use. That is what will determine how long it will last
Retired1
surgtech56
michigan
What exactly does the annode rod do?
Gary.
Yukon, OK
The Suburban water heaters need them and the Atwood water heaters do not need them. It is a rod that sacrifices itself and is eaten up due to dissimilar metals in the water heater. If you did not use an anode rod the electroalisis would eat up you water tank causing corrosion and leaking.
Old-Biscuit
Across the USA
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
