RV.Net Open Roads Forum: Truck Campers: 4 Step Scissor Steps
 > 4 Step Scissor Steps
articfox1955
Delaware
Posted: 05/06/12 10:03am Link  |  Print  |  Notify Moderator
Need advice...I have an Artic Fox/Northwood 1150 that I really enjoy; however, I want a better step than the stock step I have. I have a ground step stool that I use to step onto the camper step which helps but, on the truck it is still a heck of a step up. I'm 6'2" so not a big deal, but someone 5'2"....Anyway, considering the scissor step from Eastend Campers but not sure if this will work. Anyone have suggestions?
ejfranz
Maple Ridge, BC, Canada
Posted: 05/06/12 10:10am Link  |  Print  |  Notify Moderator
I went from the 4 step to the 5 step scissor for my Adventurer. Check out your RV parts dealer for what is available.
06 Chevy Silverado 3500 Crewcab SRW 4WD - Allison 6 speed & Duramax LBZ.
Upgrades: BD diesel exhaust manifold, Edge Evolution, Timbrens & KYB Monomax.
Camper: 2005 Adventurer 90FWS - Electric jacks, LEDs, 6V batteries, roof rack, ladder & awning.
kerry4951
East Central Pennsylvania
Posted: 05/06/12 10:42am Link  |  Print  |  Notify Moderator
I went with the Glowstep by Torklift. I also use a 4 step set up, and it mounts to the rear bumper of my 1140 (same as the 1150). I then used one of the factory steps, inverted (upside/down), and built an extention piece that slides under the factory step to raise the height plus it widens that last step while entering and exiting the TC. When we travel I use just the glowsteps, but if we park and set up for a few days I always install the inverted step and insert for added security and comfort.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
msiminoff
Silicon Valley, CA
Posted: 05/06/12 11:02am Link  |  Print  |  Notify Moderator
I suggest that you take a look at the TorkLift GlowSteps.
I have a similar set of scissor steps on my TC and they work great, stow easily, and are surprisingly stable. The only downside is that they are very slippery when wet or icy.
Cheers
-Mark
'04 Alpenlite Saratoga 935, 326W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins, Goerend Trans, Vision 19.5 w/XDE's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Thuren trackbar, RS9000XL/MyRide
AnEv942
CA
Posted: 05/06/12 12:54pm Link  |  Print  |  Notify Moderator
I also mounted our scissor steps to camper flip over step in the stored position. It decreases the step out of the camper, which on our basement-is a lot. It also gives a bit of a landing, width of flip step plus width of top scissor step. Going flush to bumper was just too much from door sill.
But to answere you question-yes they would work-just options how you mount. Ours came with the ushaped bracket shown that mounts-then the steps have a bracket that slips in it- I removed the step bracket, slip edge of step into mounted u bracket so have a larger landing at door. Ive sinces added spacers shown on both sides of flip step -decreased distance from door to 'landing' another inch.
Tapped bracket and added the thumb screw in center of mounted bracket, drilled a hole in top step flange. After inserting step turn in the screw to keep steps from jumping out. We carry our steps loose. If not setting up the scissor steps-we just use flip over step & small folding step thats stored inside of door if more than just hopping in.
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
campguy3040
Eastern Iowa
Posted: 05/07/12 06:45am Link  |  Print  |  Notify Moderator
I had the same situation with the high step from the bumper to the entry. I got the Glow Steps 6 step, and mounted it just under the door. the steps are now equal from the ground to the doorway. Only slight inconvenience is that the steps must be folded up and bungeed up to get access to the small pullout tray. The steps are nice and safe. I have the Glow Handle too. The steps are a popular item here with fellow TCers. Pictures in my Photobucket albums.
2012 Winnebago Vista, Triple Slide Ford F53.
Blue Ox Tiger Trak track bar, RoadMaster Reflex Steering,&
"Free sway bar Fix"
Blue Ox Alpha Tow Bar w/Patriot Brake System
Chevy HHR toad.
nwjetboat
Eugene, Or
Posted: 05/07/12 03:45pm Link  |  Print  |  Notify Moderator
I mounted a four step scissor step from Step-up Products on my Af990. They work very well, sturdy, no wobbles, plus it folds nicely under the door. I did modify them by spraying on bedliner and the no-slip grit you can get at Home Depot. Great step, good price, and he was local to me.
2003 Dodge 2500 CTD Air Bags, Rancho9000s, Helwig swaybar, Nitto 285/17E
2005 AF990
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 05/07/12 06:19pm Link  |  Print  |  Notify Moderator
If your truck camper is a basement model, does that mean you need 6 steps.
Paul
campguy3040
Eastern Iowa
Posted: 05/07/12 06:25pm Link  |  Print  |  Notify Moderator
Paul
Not necessarily. It depends on the height measurement from the ground to the mounting point. It the case of Glow Step brand, their site gives recommendation based on that measurement.
