RV.Net Open Roads Forum: Fifth-Wheels: Weighed In - Math Check
 > Weighed In - Math Check
OktsCamp
Alberta, Canada
Posted: 05/06/12 10:09am Link  |  Print  |  Notify Moderator
Mornining all. Weighed the truck and 5'er today with the following results.
2011 F-350 CC SRW 4x4 Lariat Diesel and 2012 KZ Durango 2500 D355BH 5'er.
Truck Alone
Front Axle - 4,840lbs
Rear Axle - 3,388lbs
Total GVW - 8,228lbs (GVWR is 11,500lbs)
Truak and 5'er attached
Front Axle - 4,796lbs
Rear Axle - 5,676lbs
5'er Axles - 10,054lbs
Total Truck GVW - 10,472lbs (11,500 GVWR)
Total GCW - 20,526lbs (GCWR 23,000lbs if I recall)
Pin Weight - 2,244lbs (19%)
5'er Weight - 12,298lbs (GWVR 13,000lbs)
5'er is FULL, less some food and clothing, but not much room to spare before running into 5'er max GVWR.
Truck is 1,028lbs below GVWR (still need to add wife and 10yr old boy and dogs), but should be plenty of room.
All in all...I am very pleased with the numbers, and the combination rides and handles beautifully.
2011 F-350 SD CC Lariat 4x4 6.7L Diesel
whiskyrunner
Oconto Wisconsin
Posted: 05/06/12 10:13am Link  |  Print  |  Notify Moderator
I'll be the first , u still need a dually, HAHAHAHA
2000 Ford F250,4x4 diesel short box,Firestone airbags
2004 Terry Quantum 36ft fiver,4 slides
Shepherd
St. Clairsville, Ohio
Posted: 05/06/12 10:41am Link  |  Print  |  Notify Moderator
Thanks for the info.
2012 Ram 3500 HO GCWR 30K
2012 Durango 2500
belairbrian
Alabama
Posted: 05/06/12 10:56am Link  |  Print  |  Notify Moderator
What is your Rear axle rating? Should be listed as GAWR.
TV 2003 Chevy 3500 Crew Cab Dually w Duramax/Allison
2005 Keystone Cougar 314 EFS
Reese 16K Slider Hitch, Prodigy BC, Delorme GPS
USAF Retired
spud57
Stratford PE
Posted: 05/06/12 11:07am Link  |  Print  |  Notify Moderator
Front 5250lbs 4x2, 6000lbs 4x4
Rear 7180lbs
2008 F250 XLT 4x4 SC LB V10
2010 Outback 321FRL 5th wheel
OktsCamp
Alberta, Canada
I am not near the the truck, but if memory serves its 7,050lbs or so.
OktsCamp
Alberta, Canada
Posted: 05/06/12 12:08pm Link  |  Print  |  Notify Moderator
WeBeFulltimers wrote:
Truck fuel? Firewood?
Not quite full tank.... As for firewood. I typically don't haul any. Quite content to get gouged at the campground.
Outside of maybe a couple of bikes...that should be all.
greende
Syracuse,NY
Posted: 05/06/12 11:11am Link  |  Print  |  Notify Moderator
I think those numbers look fine. Have fun & go camping!
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
WeBeFulltimers
Here & There
Posted: 05/06/12 12:02pm Link  |  Print  |  Notify Moderator
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO TIMBRENS PRODIGY B & W PATRIOT***PACBRAKE PRXB 2012 MONTANA 3585SA
sirdrakejr
Las Vegas, Nevada
Posted: 05/06/12 12:23pm Link  |  Print  |  Notify Moderator
WOW!!I think you got it!
11.500# GVWR for a SRW! Makes my 2004 Dodge SRW seem anemic. Darn. Have fun 5ing and travel safely, return home happy.
Frank
